Dunlops RVXT 265/70-16 installed
#361352
12/10/03 10:22 PM
I just got them installed today, and I have about 10+ miles of freeway experience so far.
I switched from Yokohama Geolander AT+II 225/75-16 load range D to Dunlop Radial Rover RVXT 265/70-16 load range C. All differences I noticed are due to the size difference, most probably. Dunlops are:
1. Much more comfortable than Yokos 2. Have less directional stability than Yokos (but better than OEM) 3. No so sharp steering response as with Yokos (but still better than OEM) 4. About the same aggressive tread as on Yokos 5.Seems like I lost some small chunk of power due to the new tire size and weight.
Dunlops do have the snowflake symbol on them, so they can be used as traction tires for winter.
My SUV looks great with Dunlops and visually much higher now. Dunlops are at least 1" larger than Yokos (which, in turn, were slightly larger than OEM 245/70-16).
265/70-16 tires fit ideally into the 2 gen Rodeo with 1" of "lift". I did not have to do any trimming to fit these tires. Seems like the 2 gen Rodeo was designed exactly for this size of tires.
So, Dunlops have two significant advantages over Yokos:
1. Dunlops have much broader choice of sizes and load ranges. Yokos are great tires but it is difficult to find proper size/load for the Rodeo. They are eighther too heavy or too light for the Rodeo. To the contrary, Dunlops have the best range of sizes/loads for the light trucks.
2. Dunlops have the snowflake symbol.
Everything else looks about the same.
When I'll be offroad, I'll post more impressions.
Oleg Rodeo S 2002 4WD
Oleg Axiom 4WD 2004: OME shocks, 32" BFG Mudders, RockSliderz, OME929+2" spacers, Stinkyfab bent RE rear links, front ARB locker, rear No-Slip locker, DOR front axle lowering kit, custom middle section skid plate, IronMan torsion bars. Deceased Rodeo'02 4WD.
Re: Dunlops RVXT 265/70-16 installed
[Re: holger]
#361353
12/10/03 10:39 PM
congrats on the new tires, new tires are always a nice thing to have
90 trooper. 3inch BL. 3inch Suspension, 33in BFG muds sitting on 15x8 rockcrawlers, roof rack, calmini front double tube bumper with two kc's, hypertech power chip, spare tire hi-lift mount,flipped lid with K&N drop in filter more to come
[Re: holger]
#361354
12/10/03 11:22 PM
Are you running stock aluminum rims?I am fighting over tires this week I had a 265x75x16 on a rim and it fit beautifully but I was thinking 245x75x16 to be safe, how about a pic? Thanks Doug
[Re: Bansil]
#361355
12/10/03 11:31 PM
I am running stock 16/7 steel wheels. 7" width rims are approved for Dunlops 265/70 and there should be no trouble. Pics will be available later, as I have no digital camera. I'll post pictures when I'll go to the trails and I'll make some pictures. Tires looks good - they have sidewall tread of about 1/2 heights of side walls. Are you running stock aluminum rims?I am fighting over tires this week I had a 265x75x16 on a rim and it fit beautifully but I was thinking 245x75x16 to be safe, how about a pic? Thanks Doug
[Re: holger]
#361356
12/11/03 12:07 AM
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" /> I guess I'll order the tires tomorrow!!! Is your spare on the back or under?Mine will go alittle higher and maybe spaced out to clear glass. We want pics!!We want pics...ugh..well...I want pics!! J/K I'll probable have them on before then. <img src="/forums/images/graemlins/smile.gif" alt="" /> Thanks for quick responce. Doug
[Re: Bansil]
#361357
12/11/03 12:20 AM
Hi Doug My spare in under. I do not want to have large WIDE expensive spare under the body, and I am not sure that I can fit 265/70 under. So, I run old 225/75 spare and I am going to make some measurements to find out which spare size I can fit under. I hope I can fit 215/85 - they are of the same diameter as 265/70 but 215s are much thinner and they will bite less road clearence. Also, they are less expensive. Best regards, Oleg Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" /> I guess I'll order the tires tomorrow!!! Is your spare on the back or under?Mine will go alittle higher and maybe spaced out to clear glass. We want pics!!We want pics...ugh..well...I want pics!! J/K I'll probable have them on before then. <img src="/forums/images/graemlins/smile.gif" alt="" /> Thanks for quick responce. Doug
[Re: Bansil]
#361358
12/11/03 12:23 AM
Doug, when you will be ordering the RVXTs, be cautious - they can mess them with RVs. To be safe, insist on LT265/70-16 load C - no other Dunlop tire has such size/load. Oleg Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" /> I guess I'll order the tires tomorrow!!! Is your spare on the back or under?Mine will go alittle higher and maybe spaced out to clear glass. We want pics!!We want pics...ugh..well...I want pics!! J/K I'll probable have them on before then. <img src="/forums/images/graemlins/smile.gif" alt="" /> Thanks for quick responce. Doug
[Re: holger]
#361359
12/11/03 06:36 AM
Today we have a rain and the roads are wet. I had to spend some time on the road. I can say that Dunlops have amasing grip on the wet pavement - I've not been able to slide at all, which was quite easy on Yokohamas. May be, this is becouse these Dunlops are wider than my Yokos were.
Oleg
[Re: holger]
#361360
12/11/03 10:56 AM
Im actually getting some M/T's but I will get them in that size.I was more concerned with that size fitting I tried 1 and it looked good so....Thanks for the help. Doug Lisa had spare under hers but the sidewalls take alot off abuse and I have seen bent/cracked wheels and cut tires if you wheel alot.
[Re: Bansil]
#361361
12/11/03 05:13 PM
On-Topic - About how much were the MT's you were looking at, Doug? Off-Topic - Lisa [bold]had[/bold] spare under hers but the sidewalls take alot off abuse and I have seen bent/cracked wheels and cut tires if you wheel alot.
So what did you wind up doing with the spare? I'm curious, because I don't like mine underneath.
-john
99 Rodeo 3.2L 4WD
