Page 1 of 3 1 2 3
Dunlops RVXT 265/70-16 installed #361352 12/10/03 10:22 PM
holger Offline OP
I just got them installed today, and I have about 10+ miles
of freeway experience so far.
I switched from Yokohama Geolander AT+II 225/75-16
load range D to Dunlop Radial Rover RVXT 265/70-16
load range C. All differences I noticed are due to the
size difference, most probably. Dunlops are:
1. Much more comfortable than Yokos
2. Have less directional stability than Yokos
(but better than OEM)
3. No so sharp steering response as with Yokos
(but still better than OEM)
4. About the same aggressive tread as on Yokos
5.Seems like I lost some small chunk of power due to the
new tire size and weight.
Dunlops do have the snowflake symbol on them, so they can
be used as traction tires for winter.
My SUV looks great with Dunlops and visually much
higher now. Dunlops are at least 1" larger than Yokos
(which, in turn, were slightly larger than OEM 245/70-16).
265/70-16 tires fit ideally into the 2 gen Rodeo with 1"
of "lift". I did not have to do any trimming to fit
these tires. Seems like the 2 gen Rodeo was designed
exactly for this size of tires.
So, Dunlops have two significant advantages over Yokos:
1. Dunlops have much broader choice of sizes and load
ranges. Yokos are great tires but it is difficult to find
proper size/load for the Rodeo. They are eighther too heavy
or too light for the Rodeo. To the contrary, Dunlops
have the best range of sizes/loads for the light trucks.
2. Dunlops have the snowflake symbol.
Everything else looks about the same.
When I'll be offroad, I'll post more impressions.
Oleg
Rodeo S 2002 4WD
Oleg
Deceased Rodeo'02 4WD.
Re: Dunlops RVXT 265/70-16 installed [Re: holger] #361353 12/10/03 10:39 PM
Dank4x Offline
congrats on the new tires, new tires are always a nice thing to have
90 trooper. 3inch BL. 3inch Suspension, 33in BFG muds sitting on 15x8 rockcrawlers, roof rack, calmini front double tube bumper with two kc's, hypertech power chip, spare tire hi-lift mount,flipped lid with K&N drop in filter more to come
Re: Dunlops RVXT 265/70-16 installed [Re: holger] #361354 12/10/03 11:22 PM
Bansil Offline
Are you running stock aluminum rims?I am fighting over
tires this week I had a 265x75x16 on a rim and it fit beautifully but I was thinking 245x75x16 to be safe,
how about a pic?
Thanks Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Dunlops RVXT 265/70-16 installed [Re: Bansil] #361355 12/10/03 11:31 PM
holger Offline OP
I am running stock 16/7 steel wheels. 7" width rims are
approved for Dunlops 265/70 and there should be no trouble.
Pics will be available later, as I have no digital camera.
I'll post pictures when I'll go to the trails and
I'll make some pictures.
Tires looks good - they have sidewall tread of about 1/2
heights of side walls.
how about a pic?
Thanks Doug
Oleg
Re: Dunlops RVXT 265/70-16 installed [Re: holger] #361356 12/11/03 12:07 AM
Bansil Offline
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" /> I guess I'll order the tires tomorrow!!!
Is your spare on the back or under?Mine will go alittle higher and maybe spaced out to clear glass.
We want pics!!We want pics...ugh..well...I want pics!!
J/K I'll probable have them on before then. <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks for quick responce.
Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Dunlops RVXT 265/70-16 installed [Re: Bansil] #361357 12/11/03 12:20 AM
holger Offline OP
Hi Doug
My spare in under. I do not want to have
large WIDE expensive spare under the body,
and I am not sure that I can fit 265/70 under.
So, I run old 225/75 spare and I am going to make some
measurements to find out which spare size I can fit under.
I hope I can fit 215/85 - they are of the same diameter
as 265/70 but 215s are much thinner and they will bite less
road clearence. Also, they are less expensive.
Best regards,
Oleg
Doug
Oleg
Re: Dunlops RVXT 265/70-16 installed [Re: Bansil] #361358 12/11/03 12:23 AM
holger Offline OP
Doug, when you will be ordering the RVXTs, be cautious -
they can mess them with RVs. To be safe, insist on
LT265/70-16 load C - no other Dunlop tire has such
size/load.
Oleg
Doug
Oleg
Re: Dunlops RVXT 265/70-16 installed [Re: holger] #361359 12/11/03 06:36 AM
holger Offline OP
Today we have a rain and the roads are wet.
I had to spend some time on the road.
I can say that Dunlops have amasing grip on the wet
pavement - I've not been able to slide at all, which was
quite easy on Yokohamas. May be, this is becouse these
Dunlops are wider than my Yokos were.
Oleg
Oleg
Re: Dunlops RVXT 265/70-16 installed [Re: holger] #361360 12/11/03 10:56 AM
Bansil Offline
Im actually getting some M/T's but I will get them
in that size.I was more concerned with that size fitting
I tried 1 and it looked good so....Thanks for the help.
Doug
Lisa had spare under hers but the sidewalls take alot off
abuse and I have seen bent/cracked wheels and cut tires
if you wheel alot.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Dunlops RVXT 265/70-16 installed [Re: Bansil] #361361 12/11/03 05:13 PM
slappy Offline
On-Topic -
About how much were the MT's you were looking at, Doug?
Off-Topic -
Lisa [bold]had[/bold] spare under hers but the sidewalls take alot off
if you wheel alot.
So what did you wind up doing with the spare? I'm curious, because I don't like mine underneath.
-john
99 Rodeo 3.2L 4WD
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6461 MB (Peak: 0.7690 MB) Data Comp: Off Server Time: 2026-06-23 21:45:44 UTC
