Page 8 of 8 1 2 3 4 5 6 7 8
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362408 10/17/11 03:55 AM
I have the same non-smooth idling issue. Am very interested to see what you come up with.
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362409 10/17/11 08:42 PM
Canyonero Offline
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: Mudraider] #362410 10/18/11 12:31 AM
mike5 Offline
In my case bad idle issues turned out to be related to the EGR and its metal pipe. This caused rough idle issues. I also had a high idle issue and occasional no starts which ended up being the coolant temp sensor.
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mike5] #362411 10/19/11 03:03 AM
I took the propane to it this evening. It seems to be a small leak at the front of the butterfly shaft. I will have to remove the entire assembly and play with different sized o-rings in the groove of the front bushing until it snugs up tighter.
I sprayed the gas (unlit!) all around the intake parts, but every time I hit the front of the lower plenum, up went the idle, then it would fall back when I removed the nozzle.
In other news, I called my brother to ask him to ask his machine shop friend about making more of the aluminum-bronze bushings, so I should know soon how much they'll cost me. And, with having a semi-functional spare now, I can rebuild it myself to see how much of a hassle it is and know how much the total to redo others will be.
It is somewhat reassuring to see the one that came off my truck is worn in the same places.
Stay tuned!
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362412 10/19/11 03:49 AM
mxmikie Offline
Stay tuned!
i think nasa should get a propane torch on the next shuttle ........ its never the machine work its the seal job that causes all the trouble
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mxmikie] #362413 10/19/11 03:51 AM
At least the consequences are less-than-lethal.
What can I say, Mx...you were right.
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362414 10/19/11 11:11 PM
Va_Stumpy Offline
Maybe this has been covered...I have a 3.5 in an'02 Dodge Intrepid R/T.(mitsu engine.I'm pretty sure) Does the butterfly issue apply to this as well?
Thanks in advance.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6287 MB (Peak: 0.7043 MB) Data Comp: Off Server Time: 2026-06-20 19:16:29 UTC
