'86 rear diff ??? #364326 12/16/03 04:29 PM
Sword King Offline OP
I can't remember if it was on this forum or not, but IIRC there were some problems with the pinion bearings in '86 Troopers. I remember something about some sort of "squishable" nut or bearing adjustment. But after searching this and other forums for a couple hours, I couldn't find anything. Does anyone know what I'm talking about? Is that info available somewhere?
2x '88 2.6L Troopers (one for parts)
'86 2.3L Trooper
'99 Acura SLX
Re: '86 rear diff ??? [Re: Sword King] #364327 12/16/03 07:07 PM
mlclark Offline
Isuzu Moderator
I don't remember hearing about bearing problems in the rear 10-bolts. There shouldn't be many problems, unless it was run low on fluid, or the fluid was contaminated.
Isuzu does use a crush sleeve to adjust pinion bearing pre-load. This goes between the nut and the outer pinion bearing and is a one time use item. If it squished too far, you need a new one. If you have problems, you probably need to have someone look at it. Diffs do not randomly have problems with the bearing preloads or settings. Something else must be wrong.
Good Luck,
Michael
Re: '86 rear diff ??? [Re: mlclark] #364328 12/17/03 03:28 PM
The one I bought last year had a problem, which my dad's mechanic solved by installing a used '87 complete axle (with new brake pad and turned drums). But another '86 has come into my life, and I don't want similar troubles, so I was looking up that crushable sleeve thing which is the only problem I remember about the '86 diff.
'86 2.3L Trooper
'99 Acura SLX
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5931 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-11-01 22:17:18 UTC
