Page 2 of 3 1 2 3
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365595 12/20/03 03:10 AM
from what I gather 3 is your hot 12 volt wire,2 and 4 are power wires that go to the antenna motor and 5 should be your ground,,,,the shorting of 5 to the others in the normal position acts as an electric brake which is comon on motors helps to slow them down faster,, you may have noticed this on small cordless drills like makitas etc when you let off the trigger the motor doesnt spin very long,,,its a saftey thing....Jason
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365596 12/20/03 04:05 AM
hilux_1990 Offline
The part # 84760-60030 is listed for the following models:
Lexus LX 450 1996-1997 Switch, Antenna 97
Lexus LX 450 1996-1997 Switch, Antenna 96
Toyota Land Cruiser 1991-1997 Switch, Antenna
I have a feeling the switch design may have actually changed for the Landcruiser 1997 model year.
1990 HiLux Xtra-Cab
Re: Power Antenna Modifications, the quest of knowledge [Re: TOY4ICK] #365597 12/20/03 09:29 AM
Sargent 'D' Offline OP
If you let me know which year the switch is from, I can look up the wiring diagram and let you know which wires go where.
TOY4ICK
Thanks TOY4ICK!
And thanks to to the rest of you two!
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365598 12/20/03 08:02 PM
Put the switch in. Pulled all my hair out.
Leads:
Lead 1. Positive 12v for the lights
Lead 2. For the down button
Lead 3. For the down button
Lead 4. For the up button
Lead 5. For the up button
Lead 6. Ground for the lights.
Now, I hooked it all up, and turned the radio on. Antenna goes up as it should. I push and hold the down button, and the antenna goes down like it should. Soon as I release the down button, the antenna goes back up. So now I'm frustrated. To start off, I cut the wrong wire. Cut some small antenna wire (the small one next to the big one inside the dash that comes out the back of the stereo). So I can't put it back together cuz it's coaxial or some thing...wire inside of a wire. So I finally find the antenna wire coming out of the amp that the toyota factory stereo comes with, it was a black wire with a white stripe on it, coming out of the amp.
So if I just used a simple toggle switch, I'd be done. Run one end of the antenna wire into the toggle, then out back to the other part of the wire. But with the fancy toyota switch I "had" to have, it isn't that simple. I can get the antenna to go up and down, just can't get it to stay down unless I turn the radio off, or use the tape or CD player. The important thing is...I got the lights to work. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365599 12/21/03 12:18 AM
lead 2345 cant all go to the motor,,,and unless you know how to wire a dpdt togle switch as a motor reverser then you cant sipmly make 1 hot wire make it go up and 1 hot wire make it go down,,,not unless you know how to properly solder and modify the motor with some diodes........leads 2 and 4 go to the motor,,,the switch then sends one polarity of electricity ( thru lead 2+4) to the motor in one position and the opposite in the other postion...my factory switch makes the antenna go up or down independant of the radio being on,,,,and I just ditched the stock one for a newwer cd player/stereo.
Re: Power Antenna Modifications, the quest of knowledge #365600 12/23/03 12:42 AM
TOY4ICK Offline
According to my information, the wires are as follows:
1 Power for lights
2 One side of the motor
3 Power for the motor (from cigarette fuse)
4 The other side of the motor
5 Ground for the motor
6 Ground for the light (use dashlight ground)
I used your identification numbers. Toyota numbers this switch differently.
I hope this helps and I'm sorry it took so long.
'86 4Runner SR5 - 22R-EB with V-6 Throttlebody, 2" 4Crawler B.L., Ball Joint Spacers, Rock SliderZ, TJ Coils, 5.29's, Rear Locker, 33" Duratracs
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365601 12/23/03 04:26 AM
yeah sounds like you got it right now,,,I was the annonymus user in the posts,,,but I have the user name I was trying to get now,,the other person to bug about electrical whould be 4crawler,,,aka Roger Brown,,,He knows electrical,,,he better.....have fun any more questions just hollar my way,Jason
Re: Power Antenna Modifications, the quest of knowledge [Re: TOY4ICK] #365602 12/23/03 04:33 PM
Right on man, Thanks a million. I have some time off between Christmas and New Years to figure this out. Out of curiosity, what did toyota have posted for the leads?
So I don't use the antenna wire from the radio at all. How funny is that. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Power Antenna Modifications, the quest of knowledge [Re: TOY4ICK] #365603 12/23/03 04:39 PM
Stupid Question time...
2. One side of the motor. What is this? Up?
4. The other side of the motor. What is this? Down?
3. Should I just tap into the fuse?
Got the lighting to work great. About all I got to work. <img src="/forums/images/graemlins/lol.gif" alt="" />
When I do this, I am going to remove the wheel well cover, and take a look at the antenna unit, wire colors, etc... So hopefully this will go smooth.
Again, thanks.
1 Power for lights
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365604 12/23/03 06:42 PM
Well if you dont get the function you want from the up down button,,,,ie when you push up the thing goes down....and when you push down it goes up,,,,then just swap the 2-4 leads either at the switch or at the motor,,,it will give the same effect,,,,,and in a few day I might find my manual and give you color codes to the wires if I can find them,,,,,,,one rule of thumb,,,any wire that is black with a white stipe is a ground wire,,,negative lead...Jason
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6374 MB (Peak: 0.7461 MB) Data Comp: Off Server Time: 2026-10-24 02:37:36 UTC
