Power Steering problems #366623 12/21/03 07:24 AM
Flouris Offline OP
I have an '89 Wrangler and the power steering seems to be acting up. The power steering cuts out periodically while turing the wheel. I checked the power steering fluid level and it was a bit low so I added some more hoping that would solve the problem, but unfortunately it did not fix anything. If anyone has any ideas on what it could be and how to fix it please let me know. Thanks.
'95 Wrangler, 4.0L, Rock-it Air Intake, tornado, Performance Distributors Ignition kit, 31's, 2.5" Pro Comp Suspension lift, Hella fogs, Light Bar
Re: Power Steering problems [Re: Flouris] #366624 12/22/03 07:02 AM
have you checked the belt tension?
Re: Power Steering problems #366625 12/23/03 02:30 AM
Go with Sunder first. If that's good, and your fluid is good, it might be time for a new pump. Pop off the cap on the resevoir. Smell what the Jeep is cookin', if you get my drift. That fluid all comes back after the function. Somethin' burnin' there ?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5866 MB (Peak: 0.6410 MB) Data Comp: Off Server Time: 2026-06-21 09:49:11 UTC
