Re: Question regarding the optional track lock in the rear differential.
[Re: sveltax]
#367212
01/25/04 07:01 PM
Does the track lock signify that the differential case is the same as an open differential case? I have an aussie locker that fits an open D44 case, would it work in my scout's rear differential? Not quite. The Trac-lok uses a special carrier, wider in one direction to allow room for the spider gears. Notice the loaction of the clutch packs-on the outside of the spider gears. To retain the carrier and use a lunch box type locker you will need a locker designed for a D44 trac lock equipped carrier. I know there are more, but the only one I KNOW works in this carrier is the Powertrax No-Slip. Unfortunately that unit is almost as expensive as a full Detroit locker. Except you can install it yourself without resetting the gears. Good Luck Mike W
Mike Walter '98 Amigo well used '94 Rodeo in need of help '99 Ram CTD for hauling feather pillows '01 unheated shop
Thank you!
[Re: muskyamigo]
#367213
01/28/04 03:11 AM
We were unable to make a steep climb that a Jeep Cherokee just walked up. <img src="/forums/images/graemlins/baby.gif" alt="" />
Back to the drawing board on the rear locking differential.
Thanks for the reply! <img src="/forums/images/graemlins/kewl.gif" alt="" />
02 Axiom, 2.5" Indy4x Lift, Rancho 9000sx, 265/70 17 ATs, awesome Shrock Works sliders, flipped ball joints and a PV muffler.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5963 MB (Peak: 0.6449 MB) Data Comp: Off Server Time: 2026-11-15 19:26:03 UTCValid HTML 5 and Valid CSS
