Page 2 of 3 1 2 3
Re: Sizing up anti-seize [Re: NathanC] #369213 12/28/03 02:50 AM
cragdweller Offline
Antiseize is great stuff. I use it on all the equipment that I maintain on many saltwater aquarium systems at the zoo that I work at (we're talking huge systems with 1000 lb sea lions). I have multiple giant pumps (30+ hp) that are held together with stainless steel fasteners. The ONLY way to keep these things servicable is to use antiseize. And this is with SS. You can forget about getting galvanized fasteners apart in a salt environment without the blessed goop!
Many poeple think that antiseize will encourage fasteners to come loose over time. NO. It will not lead to a nut or bolt backing off. In fact, it helps with accuracy in torquing.
If you don't have any antiseize available, straight grease is almost as good. I've been using grease on my lugs for years. I regularly apply some grease to each lug every time I have a wheel off. Much better than breaking a lug!
1994 3.0L 4x4 pickup.
4.62 gears (4.22 stock), 33x10.5 BFG MTs. LSD rear. Five speed trans. 172K
Previously owned Mitsubishis:
1986 2.6L 4x4 Mighty Max, 1985 2.6L 4x4 D50
1987 2.6L Raider, 1989 3.0L Raider
1995 Montero SR
Re: Sizing up anti-seize [Re: cragdweller] #369214 12/28/03 03:36 AM
I had an uncle who worked with the Navy on anticorrosion agents. He told me one time when I was about to spray on some rubberized undercoating to 'knock dat chit off, here just paste this around where you don't want any rust, just don't get it on or near anything hot"...what was it?
waterproof grease smile Never had anything rust that I treated with plain old marine grease smile
seer
Re: Sizing up anti-seize #369215 12/30/03 06:46 AM
Sometimes I feel about half-retarded, around here, because my background is industrial mechanical work, not auto. This is something I know about, though. I was a line mechanic for about a year, and you had to do it fast, do it right, and do it without getting ANYTHING on the production line. To top things off, on some products, the downtime cost was upwards of $6,000 per minute.
Our rule(s) of thumb for anti-sieze went like this: any time two different metals touch, any time you use stainless steel, any time a part was subject to major heat changes, any time you might have to weld near the part (in other words, pull all bolts within two feet and anti-sieze them before welding) any time a part had to be evenly tightened on three or more bolts, always at least three threads, always all the way around, never with silicone tape or thread sealer, and only with thread locker if you know how to apply them together (a nylon bushing nut usually worked better in our applications anyway). The majority of the rule(s) can be explained by a couple of things: A) different metals expand at different rates, anti-sieze always helps a bolt/screw/etc. turn when you want it to. B) different metals have different tolerances to corrosion; the last thing you want is some pot metal or black iron rusting around a high-grade steel bolt; you'll destroy the one trying to remove the other. C) virtually all metals are capable ot being friction welded, galled, or stripped; therefore, see A.
Like Nathan said, Permatex is extremely good. Some claim to be great for anti-corrosion. Not true. Wipes off too easily. Like seer said, use marine grease or something along those lines.
Most of the ones I've seen are pretty good, though. They all contain copper, zinc, and graphite. Copper helps with heat conductivity. Zinc helps prevent corrosion. Graphite is the lubricant. In an industrial setting, you can pay extra for high-temp formula, but it's pretty specialized, and I don't think anyone here needs to work on their exhaust or exhaust manifold 'on the fly'.
Hope this helps.
Harrier
Re: Sizing up anti-seize [Re: fasteddy] #369216 12/30/03 03:27 PM
When it comes to companies I daydream about owning [read, companies with killer products that should be making money effortlessly], Blaster is always up there on the list.
As for anti-sieze, all bolts that will see wetness get either that or Loc-Tite...
Re: Sizing up anti-seize [Re: MontyMcV] #369217 12/30/03 10:05 PM
hotrod4x5 Offline
Lots of people swear by it, but I used it on the lugnuts on my wife's car, torqued them to specs and within a couple days they were coming lose. She felt a wobbling on the way home, luckily she stopped and called me. I had her check and she could turn most of them with her fingers! I had her tighten them with the tire changer and then I cleaned most of the stuff off and torqued them again. They stayed this time.
Rodney,95 SR 3.5 L, Rancho RS 9000's, 31x10.5-15 Bridgestone Dueler A/T's, OEM Rear locker My Monty in action!
Re: Sizing up anti-seize [Re: hotrod4x5] #369218 12/31/03 04:35 PM
I recently read on the Montero online manual (link posted by monty90), which allegedly is from Chilton's manual:
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
http://www.e-toolbox.com/ads/rq.cfm
NOTE: When changing an aluminum or special type wheel rimmed tire, finger tighten the lug nuts first, then torque them to the proper value. DO NOT use an impact wrench to tighten the wheel nuts. DO NOT use oil on either the nut or stud threads.
I don't know why this would only apply to "aluminum or special type wheel rimmed tire". I'm assuming this is to prevent potential loosening of lug nuts?
Penetrating oil:
I need to pick up some of that PB Blaster I guess (Auto Zone?) - never seen it before. I always used WD40 or Liquid Wrench, which are both ok for temporary lubing - they both seem to evaporate relatively quickly though (I also spray it on tools ocassionally to fight rust).
Anti-seize:
I've had a small can of fel-pro that I obtained from a friend at an oil refinery, and it works great. I use it on all the previously posted locations, as well as exhaust flange and manifold bolts. Hopefully I'll be able to find another can when I run out !
Re: Sizing up anti-seize #369219 12/31/03 04:51 PM
Maybe I've gotten lucky, but I've never had a bolt/nut loosen on me. I've even used it on lug nuts for aluminum wheels with no probs. As I posted above, has anyone else heard if you should take spark plugs out of aluminum heads when they are hot? I probablly wouldn't anyway, but I would like to know if where I heard that was correct or not. TNT
Re: Sizing up anti-seize #369220 12/31/03 05:18 PM
I remember hearing about not removing spark plugs from a hot engine - or maybe it was re-installing them. Probably has something to do with dissimilar metal expansion. The threads of the plug might become just enough different from the threads of the hole to mess things up. I always remove and install plugs cold, just in case.
Re: Sizing up anti-seize #369221 12/31/03 05:24 PM
That was the reason I'd heard was the diffrent expansion rates. I'm just glad I'm not totally mis-informed. Thanks. TNT
Re: Sizing up anti-seize #369222 12/31/03 05:29 PM
This is from the above-mentioned on-line manual, for spark-plug removal and installation. The section on installation does not contain a similar warning about hot/cold.
REMOVAL
NOTE: On some later models engines, removal of engine air intake plenum and other components will be necessary.
Always keep track of the spark plug cable routing and plug wire bracket locations. Number the spark wires so that you won't cross them when you replace them.
Remove the wire from the end of the spark plug by grasping the wire by the rubber boot. If the boot sticks to the plug, remove it by twisting and pulling at the same time. DO NOT pull wire itself or you will damage the core.
Use a spark plug socket or equivalent to loosen all of the plugs about two turns.
NOTE: Remove the spark plugs when the engine is cold, if possible, to prevent damage to the threads. If removal of the plugs is difficult, apply a few drops of penetrating oil or silicone spray to the area around the base of the plug, and allow it a few minutes to work.
If compressed air is available, apply it to the area around the spark plug holes. Otherwise, use a rag or a brush to clean the area. Be careful not to allow any foreign material to drop into the spark plug holes.
Remove the plugs by unscrewing them the rest of the way from the engine.
INSTALLATION
Lubricate the threads of the spark plugs with a drop of oil. Install the plugs and tighten them by hand first. Take care not to cross-thread them.
Tighten the spark plugs with spark plug socket. Do not apply the same amount of force you would use for a bolt; just snug them in. If a torque wrench is available, tighten to 15 ft. lbs. (25 Nm).
Install the wires on their respective plugs. Make sure the wires are firmly connected. You will be able to feel them click into place. Check the spark plug cable routing and always make sure the plug wires are in the correct plug wire bracket.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6314 MB (Peak: 0.7416 MB) Data Comp: Off Server Time: 2026-11-17 11:16:50 UTC
