Re: Sizing up anti-seize
[Re: rumrunner]
#369223
12/31/03 08:52 PM
I always shut's me enjin off for I pull da plugs DOH!
Whatever your preferences on the anti sieze for spark plugs.
I look at anti-seize as a contaminate. If a little should end up in the cylinder what will it do to the rings? Gum them up? What about hot spots? Oil on the other hand would burn off, but the oil can hold small amounts of dirt and then when you pull the plugs where can that end up?
Never had a problem with clean dry plug threads, hot or cold. I've hot potatoed plugs plenty of time. Overtorque or cross thread is the killer.
http://zywie.com Zywie's Law: If anything can go right, it will go right, and at the best possible time.
[Re: mag00]
#369224
12/31/03 10:28 PM
I I look at anti-seize as a contaminate. If a little should end up in the cylinder what will it do to the rings? Gum them up? I would think so because when I saw this thread I had just changed my wife's front brake pads. The antiseize was still on the lugs, but it is somewhat tacky now and actually made the lugs harder to take off and put back on after breaking lose with wrench.
Rodney,95 SR 3.5 L, Rancho RS 9000's, 31x10.5-15 Bridgestone Dueler A/T's, OEM Rear locker My Monty in action!
PHP: 7.4.33 Page Time: 0.025s Queries: 15 (0.019s) Memory: 0.5990 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-11-18 12:00:36 UTCValid HTML 5 and Valid CSS
