Page 3 of 4 1 2 3 4
Re: SAS conversion possibility... [Re: lee_raider] #369624 12/29/03 03:59 AM
CGuava Offline
strong birfield joints
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Never heard of them! Everyone I see runing birfields complains all the time about them breaking! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Also, you cannot "flip" an axle and run it upside down, or backwards.
Hey now, i've been running new treated, tested, heated and cryo'd birf's for more than a few trail runs now. These things are unbreakable. They are STRONG. Taken them through some rough colorado terrain and they're holding up. I think a toy axle is finally (because of the new birfield market) reliable and can hold for themselves up to 37" tires. I've seen 38's run on them and 44's, but i think 37's are the limit. Sure you can go to 60's, but who's got that kind of time/money?
Christian
Christian
88' Runner, SAS, Dual Cases, 529's, Locked, 37" MTR's, TR Beadlocks, blah blah.
Re: SAS conversion possibility... [Re: AcidophilusRex] #369625 12/29/03 04:46 AM
lee_raider Offline
And since you'd be having to cut down both sides anyways, to get an offset you'd just cut more off one side than the other...if that didn't leave you enough, yes, you'd have to re-tube that side.
Most 4x4 vehicles are about 1 or 2 inches narrower in the rear. I never measured the wheel mounting surface (WMS) to WMS on the Raiders axles, but I know the Waggies are 2" wider in the front (60"/WMS front, vs 58"/WMS rear). Therefore, you'd not be able to cut both sides. Of course, to cut both sides and make a center diff into a drivers side diff, the axle would need to be probably 8"-10" wider than what you want to end up with. But yea, if you retube one side....maybe it would work.
Personally I've never bought into all that "ours is better crap". No matter what vehicle forum you go to, they will all say "ours is better". I think it's bull crap. The Mitsu's are good capable vehicles. The best??? I don't believe so.
Never said Mitsu's were the BEST, just damned good, unlike a lot of 4WD vehicles out there (like YEEPS) that really don't have much going for them if they didn't have such a monstrous aftermarket. Lloyd's said it, and I believe it...Mitsu's are one of the best, out-of-the-box. If I WERE going to build a high-end rock buggy, I WOULD start with a Yeep, but only because there's such a huge aftermarket. If I want a reliable, capable, and strong vehicle, both on- and off-road with a minimum of modifications, I'll stick with the Montero. Anything that diminishes the Mitsu-ness should be avoided if possible.
I'm on the other end of that debate. If I knew then, what I know now. I would have bought a Jeep. But remember, mine is a trail only truck and is not used on the street. But that aside, I'd never get rid of it....I have gained a reputation as "lee_raider", and that is what everyone associates me with.
When it was a dual use vehicle, it was very good as far as durability goes. Seldom had any breakage problems. Just had off road capability problems, for what I wanted it to do. I wanted to do a level above what the Raider was capable of. And now I can.
However, I'm far from convinced that a Dana 44 is an adequate substitute.
I know, everyone hears about D44's breaking axles, right? Well, how many of those times is it with a 4 cylinder? Or even a 6 cylinder? The vast majority of the breakages we hear about are with V8's, which put much more power to the axles than any of our Mitsu motors ever will.
I am not saying your idea is wrong, or bad. Given enough thought and work, anything is possible, and this might be a good one. I just don't know yet.
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: SAS conversion possibility... [Re: CGuava] #369626 12/29/03 05:15 AM
Lloyd Swartz Offline
[/quote]
Christian [/quote]
Where did you get your birfields? I was going to get some Montero ones done by some guy but he wigged out.
Re: SAS conversion possibility... [Re: Lloyd Swartz] #369627 12/29/03 06:13 AM
PartyTruck Offline
As far as 38" tires? I hope you realize its then a trailer rig, and not reasonable to drive on easy to moderate trails, or much fun on most hard trails.
Lloyd was that one for me?
We have a few 38" mitsus over here and one 44", those cars are all dayly drivers and I know for a fact that the better half drives the 44" one to work in the morning. And you dont need a D-60 for 38's unless your going for somthing like a 200:1 in first gear. And 38's works better off road than a 35" CD, I've tried both and speak from experience in mud, snow and summer conditions wich are great over here for wheeling. You have way more traction and a softer tire.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: SAS conversion possibility... [Re: AcidophilusRex] #369628 12/29/03 06:41 AM
MarkG Offline
Here you go. A pair of new GM 4wd axles including brakes. SET OF FRONT & REAR GM 4WD AXLES
Re: SAS conversion possibility... [Re: MarkG] #369629 12/29/03 07:05 AM
A
AcidophilusRex Offline OP
...killing me, you are.
Re: SAS conversion possibility... [Re: MarkG] #369630 12/29/03 07:05 AM
CGuava Offline
Lloyd,
Mitsu runs a birfield typ joint?
You can get them from:
Longfields, pioneer good guy Bobby Long
or
all pro's site, they just began production of their own project.
They sell the birfs in bulk. I would check to see if they were able to do one set for you.
Christian
Re: SAS conversion possibility... [Re: PartyTruck] #369631 12/29/03 03:01 PM
DougH Offline
Mitsubishi Forum Moderator
Thats only half the truth. With our engines you can probally get away with a d44, and 38's. You could probally even throw the 38's on the ifs. However you would have to baby the crap out of the truck, and it wouldnt last long even with really carefull driving. Rocks put a hell of alot more strain and bind on a axle then snow does, it would be a question of when you were going to blow a ujoint or an axle, not if.
DougH
1995 SR - RIP
1993 RS - RIP
Re: SAS conversion possibility... [Re: DougH] #369632 12/29/03 03:40 PM
Good point Doug. Also have to remember to run 38s you would need even more gears to run 38s then I have, and that also snaps axles along with lockers. Now I assume youll have 2 lockers before you got 38s, but around here.... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Guava, Bobby Long was the one that wigged out on me, maybe I will call the other guys. After agreeing to do some he claimed he could not figure out how to dissasemble them after he got them <img src="/forums/images/graemlins/confused.gif" alt="" /> An axle expert <img src="/forums/images/graemlins/confused.gif" alt="" /> He screamed at me for not sending return postage <img src="/forums/images/graemlins/confused.gif" alt="" /> Dude, dont I have to send you payment for the product as well when your done <img src="/forums/images/graemlins/confused.gif" alt="" /> Then his wife mailed the axles back to me and said he was sick and could not work on them <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: SAS conversion possibility... [Re: Lloyd Swartz] #369633 12/29/03 04:11 PM
DougH Offline
I dont think Long does the axles any more. I remember reading a post about how alot of people were taking advantage of him and what not. Every one seemed to think he was a awesome guy. Unfortunately I think you just got him at a bad time, and the end of a bumpy road. I could be wrong, but as far as I know he sold the manufacturing rights or something like that.
DougH
1995 SR - RIP
1993 RS - RIP
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 2.919s Queries: 16 (0.017s) Memory: 0.6523 MB (Peak: 0.7801 MB) Data Comp: Off Server Time: 2026-11-06 23:09:04 UTC
