Page 4 of 4 1 2 3 4
Re: SAS conversion possibility... [Re: Lloyd Swartz] #369634 12/29/03 04:17 PM
FranklinP Offline
Coming from the full size world a few thoughts. All your tire size ratings on axles are for full sized trucks. The Dana 44 max tire size is 35's, the dana 60 is 39's. Rockwells are 44's and up. However my personal experience is to keep the front open and really never have any issues at all. I did a 1 ton swap on last truck and could drive a front wheel onto a power pole and pull the truck up with 39's. The d-60 is very stout.
200:1 ratio to run big tires? I had 4.56's and stock t-case. The v-8 torque made up for the rest. Compression braking was enough to keep under control.
You guys cant use chevy stuff because the diff is on the wrong side anyways. And for the record a d-60 , 14 bolt FF combo with 4.56's and rear detroit are in every CUCV made. If you cant find locally then Boyce equipment will ship to your door for $3k. This is the non-refurbished price. Remember you can get a highly modified Sammi for cost of a SAS in montero. Plenty of after market and plenty of power with tracker motor swap. (Included in the highly modified part.) <img src="/forums/images/graemlins/kewl.gif" alt="" />
1989 Dodge Raider V-6, 33" Swampers.
Raider pics
Re: SAS conversion possibility... [Re: FranklinP] #369635 12/29/03 05:47 PM
DougH Offline
Mitsubishi Forum Moderator
I can find dirt cheap 14 bolt ff's in all my local yards, I looked. The hard part is lifting it into the truck. <img src="/forums/images/graemlins/baby.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
The axles from a 78-79 F350 would be a perfect match, if you wanted to go all out. They are high pinion so they would go great with a swb, and they are pass side drop. Also no balljoints, it is a kingpin axle.
Combine that with a 4.3 swap, with a chevy tcase... mmmmmmm yummy.
Some day, I just have to get school done first. Then the nice shop will fall into place. <img src="/forums/images/graemlins/smile.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: SAS conversion possibility... [Re: DougH] #369636 12/29/03 05:56 PM
A
AcidophilusRex Offline OP
[The axles from a 78-79 F350 would be a perfect match, if you wanted to go all out. They are high pinion so they would go great with a swb, and they are pass side drop. Also no balljoints, it is a kingpin axle.
And then you don't have a Mitsubishi anymore...you have a FrankenChevy.
Re: SAS conversion possibility... [Re: DougH] #369637 12/29/03 06:03 PM
lee_raider Offline
The axles from a 78-79 F350 would be a perfect match,....... and they are pass side drop.
Passenger side drop?? Perfect match?????? <img src="/forums/images/graemlins/confused.gif" alt="" />
Is Dougie typing faster than he is thinking again??? <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: SAS conversion possibility... [Re: lee_raider] #369638 12/29/03 06:30 PM
DougH Offline
I ment Japanese passanger side drop. Ummmm sure. <img src="/forums/images/graemlins/notooth.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: SAS conversion possibility... [Re: AcidophilusRex] #369639 12/29/03 06:35 PM
DougH Offline
I dont understand this logic at all. I enjoy owning a mitsubishi as much as the next guy. However, if you are going to offroad the truck, and take the time and money make it more capable, it is the performance and durability that maters, not what make the parts came from.
Along the same line of thought, why stick after market springs, or differentials in the truck. Why put 33's on the truck they arent stock.
Getting the rig over the obstacle is the end all objective, regardless of what pushes it over.
DougH
1995 SR - RIP
1993 RS - RIP
Re: SAS conversion possibility... [Re: DougH] #369640 12/29/03 06:40 PM
FranklinP Offline
The D-60 is the money axle. I got my 14ff from boyce for $700?? but it had the detroit and 4.56's and they rewelded the perches to the 1/2 ton width for me. I see them around here for $100. If I did it again I would get a 14ff out of a 1 ton van since they are wider than the trucks. Decreases turning radius I guess.
Raider pics
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6257 MB (Peak: 0.7348 MB) Data Comp: Off Server Time: 2026-11-05 08:25:49 UTC
