Re: Super Swamper tires?
[Re: SHERRI_GIRL]
#373418
01/07/04 02:46 AM
Sorry bout not getting back been a bad couple of days! Anyway, I bought these tires from 4wheelparts.com along with 4 rims (ar-40?) for about a grand back in '99. I run them with 22-24 psi and my guess would be arond 30-35000 miles (mostly road English 4x4 parks aren't that great) The reason for the "oval" call came from a buddy of mine who is an advid 4x4 guru (although in a jeep) and noticed that when i was driving the left rear well would "bounce" or roll like an egg from tip to tip so this weekend i am going to remove it and see what i can find. I will let you know whats up with it after then.
#373419
01/07/04 08:21 AM
wow, must be pretty bad if you can feel it in the back. Please let me know what else you find out. Did you let the truck sit for a long while?
[Re: SHERRI_GIRL]
#373420
01/09/04 02:15 AM
No, if it sits its only over the weekend while we drive the NONE BOUNCER to see family. I will get a garage on Sunday nad if i have time will try to post pics and update.
Re: Super Swamper tires? UPDATE!
#373421
01/16/04 12:36 AM
Well finaly had time to look a little further into this. I jacked the truck up and checked the wheel assy for any play and luckily there was none. So i can safely say that the shafts and bearings seem to be in good shape. However when i spun the wheel around it did seem "lopsided" or "ovaled". I noticed that as the wheel slows down to a stop it will continue its momentum as if it is over ballanced heavily on one side. Sure enough i look inside the rim and there lay the original weights i used 4 years ago. So i am going to have them ballanced this weekend and see how they are. I hope that they haven't worn this way too bad as i need to save up monies for new tires.
#373422
01/16/04 08:52 AM
Please let me know if balancing helped the problem. Btw- how much tread do you have left on em after 4 years? And about how many you estimate you have on em?
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6031 MB (Peak: 0.6655 MB) Data Comp: Off Server Time: 2026-06-17 11:37:49 UTCValid HTML 5 and Valid CSS
