Bent Tie Rod #373837 01/05/04 08:34 PM
A
axledeep Offline OP
On my first wheeling trip with my "new" 4Runner, I hit a nasty rock while playing in some ice and bent the tie rod (1985). So, of course I need to get it aligned, for the second time in 7 days <img src="/forums/images/graemlins/frown.gif" alt="" /> . I am hoping it can be brought back into alignment even with the bent rod, but does anyone know if there is anything else I need to pay particular attention to in checking for breaks, cracks, bends....regarding the front suspension/steering? The impact was great enough to chip a good chunk of my wheel off, blow the steering stablizer, and swing the truck around 90 degrees in a heartbeat.....tipping it up on 2 wheels and almost laying it on its side in the process. It was quite a ride...... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Bent Tie Rod [Re: axledeep] #373838 01/05/04 08:40 PM
DirtyHarry Offline
Toyota Moderator
You need a new tie rod, you cannot realign the vehicle with the bent tie rod. Once it is bent the strength has been greatly compromised, even if it is straightened. All-Pro or Rockstomper can set you up with a heavy duty tie rod, or you can likely find a stocker from someone who has converted to Hysteer.
Re: Bent Tie Rod [Re: DirtyHarry] #373839 01/05/04 08:44 PM
A
axledeep Offline OP
Bummer, thanks Harry.
Re: Bent Tie Rod [Re: axledeep] #373840 01/05/04 08:57 PM
Red_Chili Offline
Toyota Section Staffer
Or go to the boneyard. Cheeeeeeeep. No one wants 'em.
-Bill
Re: Bent Tie Rod [Re: axledeep] #373841 01/05/04 09:00 PM
W
whitetoy Offline
I'm all for strength, like a heavy-duty tie rod BUT .....
if axledeep was running one at the time of his incident,
what would have happened ? <img src="/forums/images/graemlins/confused.gif" alt="" />
He could have broken a tie-rod-end, or steering arm,
whatever the weakest point is <img src="/forums/images/graemlins/shame.gif" alt="" />
At least he could drive it home with just a bent tie-rod.
I ran a slightly bent one for years with no problem.
The FSM shows how to correct the toe-in, don't need to take
it to a shop. Don't need perfection for wheeling.
Just my .02 cents worth. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 7.010s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-06-22 14:58:51 UTC
