Page 4 of 4 1 2 3 4
Re: starter not working #377046 01/13/04 03:30 PM
foxtrapper Offline
I have question for you. I've done the replace the contact / clean up the plunger bit on several starters, and had less than stellar long term results. Generally in less than a year I'm back to where I started, clicking and such. Yet if I replace the starter with a rebuilt unit, the problem goes away and stays away for many years. What am I missing?
i used to rebuild starters and altonators for a living
'97 T-100 SR5
Re: starter not working [Re: SHAD] #377047 01/14/04 12:57 AM
Well this morning I went to crank my 4 runner up for work it didn't start. I checked all the normal things connections grounds etc. I found the battery was somewhat dead. I brought it to the parts store it had a tested it had a bad cell so I bought a optima red top. I put the red top in it still does the same thing. It sounds like it is trying to turn over make a little noise but not a full starter turn over noise. I tried jump starting it still the same. I got a used starter relay from a taco still nada. I can crank the egine by hand so it's not seized so what could it be? Could the starter have a flat spot in it? I am a little frost bitten and frustrated at this point since it is about -18 deg with the windchill.
[color:"red"] I'm not sure I follow you- is it turning over slowly or not? If so, the you're NOT getting enough current to the starter. It's not enough to have 12 volts. The cable has to be in good enough shape to dump a couple of hundred amps into the motor, otherwise, no go. If it's *not* cranking over at all, then it may be in the primary circuit (starter contacts, ignition key switch, bad starter relay, etc.)
4Crawler has a really good write-up on starter diagnosis, but I don't have the link. Ask him and he'll point the way.
The good news is that this stuff isn't rocket science. You'll get it done eventually. Just keep plodding along.
Good luck!
PS *CLEAN* your terminals on both ends of the cable!
[/color]
Re: starter not working #377048 01/14/04 03:24 AM
SHAD Offline OP
The noise was the solinoid plunger actuating. However it wasn't making contact to the main power lead so the starter motor wasn't turning over.
Replacing the contacts did fix the starter.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6006 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-06-22 23:03:54 UTC
