Page 1 of 3 1 2 3
Check Engine Light #377900 01/11/04 04:50 AM
JeepMedic Offline OP
The check engine light is always on in my '94 Wrangler. I have replaced/cleaned all of the components that according to my "Haynes" manual the computer was referring to. Is there a way that I can reset this system? Anyone have any suggestions????
Just a used 4 cyl '94 Wrangler
Re: Check Engine Light [Re: JeepMedic] #377901 01/11/04 04:59 AM
I have your answer, maybe you can help me out after, i asked a ? 2 down from yours regarding jeep lifts on my Cherokee, but about you reseting the system, yes it's very easy, disconnect the negative cable on your battery for 5 minutes, reconnect, and if the problem was solved by the parts you changed, your light wont come back on until something else is wrong. their you go. good luck. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Check Engine Light #377902 01/11/04 05:03 AM
I have tried that before and the same codes keep coming back even after I replaced the sensor. I'll try it again. Thanks.
I don't know if I'll be able to help you or not but I'm going to look at you post right now.
Re: Check Engine Light [Re: JeepMedic] #377903 01/11/04 08:45 AM
You only have to disconnect the battery for about 10 seconds or so and then it should reset itelf. Runn the engine around town for a bit and if ya can on the freeway for about 20 mins or so then stop and recheck the codes. Use the Jumper techniqe to get your codes. See if any new codes have poped up. What are the codes that pop up?
Keep On Jepin!!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Check Engine Light #377904 01/11/04 08:54 AM
if you keep getting the same codes and you have replaced the sensor then you have some other problem. which sensor/ system is the code for?
Re: Check Engine Light #377905 01/13/04 03:34 AM
Okay, how do you use the jumper techniqe to get the codes?
I have just been getting the codes the way my "Haynes" manual says to.
Re: Check Engine Light [Re: JeepMedic] #377906 01/13/04 03:39 AM
fishtaker Offline
You could always clip the wires to the light. No more problems.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: Check Engine Light [Re: fishtaker] #377907 01/13/04 03:44 AM
Man, it's been a loooooonggg time since you could clear any codes by disconnecting the batt. Are you boys sure you can still do that in a '94 ?
Re: Check Engine Light #377908 01/13/04 03:56 AM
flyfishingjeep Offline
Works on my 99
Re: Check Engine Light [Re: flyfishingjeep] #377909 01/13/04 04:04 AM
That's good to know, because it didn't clear the codes in a '97 Grand Cherokee. I guess there's exceptions to every rule, no ?
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6234 MB (Peak: 0.7286 MB) Data Comp: Off Server Time: 2026-10-31 04:35:56 UTC
