Page 12 of 16 1 2 … 10 11 12 13 14 15 16
Re: I'm not crazy -I really have more power now! [Re: tlab] #379988 01/23/04 12:23 AM
here Offline OP
Tiab, Kia can tell the dealer to 'take it out' if your in the Philippines cuz it doesn't get cold anywhere here. I'm curious what Kia would tell CBP in Brazil if he went to them and asked about this..... But the idea of a cutoff switch sounds good for those who can take advantage of it -if it can be done.
I MAY be moving to Thailand and I MAY take sporty with me. Same climate there so I'm good to go if I do.....
Canuk in d' Philippines
'97 4x4 Sportage DOHC SOLD!
2000 4X4 Grand Sportage long body Turbo SOLD <img src="/forums/images/graemlins/frown.gif" alt="" />
Bought another (standard length) 2000 Turbo Intercooler Diesel auto4X4 smile
Re: I'm not crazy -I really have more power now! [Re: here] #379989 01/23/04 01:24 AM
Dave Scott Offline
i don't think it was failure-prone, i still have mine and it's 8 freakin years old.
i didn't get to mess with it today, but i will try it tonight or tomorrow.
as for temp, i don't think we'll get down to 22 again this year, so it should be ok.
what is this rev-limiter/RPM-thing y'all 're talking about? what does it do? etc.
Re: I'm not crazy -I really have more power now! [Re: Dave Scott] #379990 01/23/04 05:58 AM
DSHornet Offline
Okay, another update.
I concluded that I was restricting the air through the solenoid circuit a little too much. When I started the car this morning, the idle didn't get much over about 1000 RPM on a cold start. It was smoother (less air = richer mixture), but the low cold idle speed bothered me. So I found some washers in my junk (miscellaneous hardware) drawer that were the same outside diameter as the hose inside diameter. I changed out the brass fittings having the hole diameter of about 1/8 inch with a washer having a hole size of about 3/16 inch. Tomorrow's cold start will show the effect.
I'm not sure it runs better, but it certainly doesn't run worse.
Don, y'all
Paw-paw Don, y'all
Favorite quote: "One need never apologize for exercising the Golden Rule."
Re: I'm not crazy -I really have more power now! #379991 01/23/04 12:30 PM
Axe Man Offline
Kia Moderator Emeritus
Is the "RPM hold" being discussed really the same as the Rev Limiter? I don't see how the IAC valve could control max RPMs... that is usually done with the ECU.
No, this is the sometimes annoying habit of the IAC "holding" the engine revs elevated for a second or two before it drops down to curb idle. It's actually the ECM commanding the IAC to do that. Seems to do it much more in the Summer when the A/C is on. Apparently the older IAC does it more frequently and possibly at a higher RPM.
You'll see this more on the stick shifts when you throw the clutch to come to a stop. You won't see it with the automatics.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: I'm not crazy -I really have more power now! [Re: DSHornet] #379992 01/23/04 12:32 PM
Axe Man Offline
Don, y'all
Will be curious to see how these tests turn out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I'm not crazy -I really have more power now! [Re: here] #379993 01/23/04 02:02 PM
Well, here in Brazil I guess they would have no idea whether I can plug it off (They'd probably say NO!). But I may try the switch thing.
Fact is that they probably build general specs to export the car wherever, and unless it is pretty justifiable for the market size (like US) they will not change a bit of the project other than to adapt to local legislation (daylight running lights in Canada, fire extinguisher in Brazil,etc.) I Wonder why Europeans get LSD and Americans don't! I've seen a sporty with electrical fan and it makes an interesting bit of difference. But the setup that I saw required some trimming to pull the radiator forward to accomodate the fan.
Re: I'm not crazy -I really have more power now! [Re: Axe Man] #379994 01/23/04 03:23 PM
Interesting. I don't believe that I've ever noticed such an occurrance. I'll have to pay more attention the next time I take the Sportage out for a drive. Thanks for clearing that up! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: I'm not crazy -I really have more power now! #379995 01/23/04 03:38 PM
fokion Offline
Hey Guys I am back - Two days without telephone lines s%$#@t..
What a thread!!!!
When my IAC was gone the car was "vibrating" anyway I will test on WKend.... it is damn cold 0 deg. celsious and minus at night.. that will give you a cold start!!!
Re: I'm not crazy -I really have more power now! [Re: fokion] #379996 01/23/04 05:38 PM
Dave Scott Offline
unplugged it last night, ran it this morning. had rough start-up, almost stalled, temp was 45*-ish F. CEL glaring at me. no noticable power gain, very slight RPM drop. drove the same at 55, 65 and 70. going to plug it back in today and forget about it, so if i do have a problem, the CEL will be able to alert me to it.
Re: I'm not crazy -I really have more power now! [Re: Dave Scott] #379997 01/23/04 06:08 PM
A
Airdale73013 Offline
what is this rev-limiter/RPM-thing y'all 're talking about? what does it do? etc. [/quote]
The rev-limiter is software in the engine management computer that limits the maximum RPM the engine will operate at under normal conditions. It keeps you from over-reving the engine.
2009 Sorento LX, 4x4, V6, Auto, Red
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6518 MB (Peak: 0.7565 MB) Data Comp: Off Server Time: 2026-11-02 08:28:42 UTC
