'85 Trooper barely running
#381369
01/16/04 07:20 AM
Hi guys, I normally hang out on the Mitsubishi boards, but I just picked up a very cheap '85 Trooper, 4cyl engine, 2dr, 4 speed manual tranny. I tried driving it home today but only got 20 miles. It kept dying like it was running out of gas, then if I waited a minute, it would start up and run a little ways further down the road. It finally got so bad I had to park it. It apparently has not been run for the past 2 years. Then a used carb was installed, then it was hauled in to a repair shop. They flushed the fuel system, put in a new fuel filter, and replaced the distributor. About that time the previous owner passd away. All further repair work was stopped, and I came and picked up the vehicle. I noticed some of the vacuum lines were not connected and I'm not sure where they are supposed to go. The engine idles very poorly. I have no previous experience working on Troopers, so I sure could use some help. First off, can you guys direct me to any online repair manuals, vacuum hose diagrams, or even some detailed photos of the engine compartment for this year Trooper? Or if you just have some advice on the problems I've described I sure would appreciate it. I tried your search function, but did not have any luck at all...maybe I didn't use the right words. Anyway I sure would like to get this truck running better. Tomorrow I am going to bring it home on a borrowed trailer. I then plan to check out the fuel filter to see if it is plugged. If that's not the problem then I'll be doing a lot of head scratching. <img src="/forums/images/graemlins/confused.gif" alt="" /> Thanks for any help.
90 Montero, 2dr, AT, V6, LSD, AC, KYB shocks, bouncy seat, 182K miles, JDM engine, 87 Starion seats, tow hitch http://www.geocities.com/idahojack03/Index
Re: '85 Trooper barely running
[Re: IdahoJack]
#381370
01/16/04 08:16 AM
What motor does it have in it? The 1.9 or the 2.3? I have a 2.3 and tons of wiring and hose diagrams for it. Might actually have some for the 1.9 too. -Nick
#381371
01/17/04 12:58 AM
I just got the Trooper home and have some more info on it. First, it's a Trooper II, I don't even know the difference, but that is what it is. It might be an 86, but I'm not sure. The label in the door says it was made Feb 85, but that might mean it is an 86 model. I don't have the title or any paperwork on it yet. The VIN # is JAACH15A3F5411392. I couldn't find an engine size, but the front of the head is stamped G200. It does have a vacuum line diagram under the hood, so I'm good to go for that problem. I'm going outside to play with it now, so catch you all later.
[Re: IdahoJack]
#381372
01/17/04 03:16 AM
Isuzu Moderator
The G200 is the 2.0LI-4 engine which wasn't available in an 86 model so I'd say you have an 85. Unfortunately, there isn't a whole lot available for the older engines, but you might want to look at options for the Impulse line as it also used that engine, along with the Trooper and the P'up
James
[Re: jezeric]
#381373
01/17/04 04:59 AM
Thanks James, you confirmed what I just read on an internet website...the '85 only came with one gas engine size, the 2.0L. Just finished routing the vacuum lines, I think they are right now. Next job is to rebuild the carb and check the fuel filter. Overall, I like the simplicity of the Trooper and look forward to tinkering with it.
[Re: IdahoJack]
#381374
01/17/04 06:09 AM
The 1.9 motor I was refering to is actually something like 1.995 liter motor, so I guess it would be the same thing. All the books I have refer to it as a 1.9 though. Anyway, best of luck with it, if you need anything I'm sure James or myself would be more than happy to help out <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
#381375
01/18/04 09:19 PM
Thanks Troopaholic, yesterday I checked the fuel filter, it was fine. Oh and by the way, I learned a little more about the Trooper--it has not been run for the past 8 years. I've decided the problem is in one of three areas: 1. The gas tank may have garbage in it that is plugging the outlet screen. 2. The fuel pump is weak. 3. The carb is varnished up inside and restricting fuel flow. I'll try to narrow down these during the next few days. I do have one question. My temp gauge is not working, where is the sensor? If I can find the sensor I can track the wiring back to the gauge and find out what the problem is. By the way, I did find an online site that has technical info covering all vehicles, it might be useful to some of you guys that don't have repair manuals. http://www.e-toolbox.com/ads/rq.cfm It asks for a password, but you don't need it, just click on the login line.
[Re: IdahoJack]
#381376
01/18/04 09:38 PM
Wow, sweet link, man! thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Troop - Posing yard art
[Re: IdahoJack]
#381377
01/18/04 10:31 PM
Thanks Troopaholic, yesterday I checked the fuel filter, it was fine. Oh and by the way, I learned a little more about the Trooper--it has not been run for the past 8 years. I've decided the problem is in one of three areas: 1. The gas tank may have garbage in it that is plugging the outlet screen. 2. The fuel pump is weak. 3. The carb is varnished up inside and restricting fuel flow. I'll try to narrow down these during the next few days. I do have one question. My temp gauge is not working, where is the sensor? If I can find the sensor I can track the wiring back to the gauge and find out what the problem is. By the way, I did find an online site that has technical info covering all vehicles, it might be useful to some of you guys that don't have repair manuals. http://www.e-toolbox.com/ads/rq.cfm It asks for a password, but you don't need it, just click on the login line. Fuel tank is probably all full of gunk from sitting that amount of time. I would drain it and clean it out anyway. Fuel pump is going to be a mechanical one right below your intake. It's ran by a pushrod activated by the cam. And the carb is also most likely varnished from sitting. You've got a little work to do, but you'll definately be happy in the end, these really are some neat trucks. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Nick
[Re: paulevans76]
#381378
01/18/04 10:57 PM
Yeah i second that! Great resource!
CHRIS 98 Amigo, 92 Pup
