Re: '90 2.8 vacuum hose routing #382195 01/26/04 08:21 PM
MeatWagon Offline OP
Yes, that vac port was properly plugged. The idle jumped a lot when I disconneted the hose to the PCV valve to check it. So I replaced the valve, but it didn't help.
I was thinking maybe my TB needs to be cleaned out? The butterflys are discolored (light tan) & the whole unit looks grubby. Could be it needs to be sprayed down & cleaned.
'90 Trooper LS 2.8, 5spd, 3" body lift, 33x12.5, dent
Re: '90 2.8 vacuum hose routing [Re: MeatWagon] #382196 01/26/04 08:39 PM
it's grubby? yeah, a "refresh" couldn't hurt. Really it's not that hard to pull the whole thing off, so I recommend if you're going to clean it anyhow, clean it on the bench. this can be done in a saturday, easily.
Be sure to reassemble the IAC motor piston with a bit of slick white moly. grease (not excessive!) so that it slides smoothly <img src="/forums/images/graemlins/kewl.gif" alt="" />
by pulling it off, that way you can be sure that the gasket underneath isn't causing a problem either smile <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5921 MB (Peak: 0.6409 MB) Data Comp: Off Server Time: 2026-06-23 13:01:31 UTC
