gear ratios and the 3.4 questions #386516 01/25/04 02:30 AM
vrooooom Offline OP
i don't understand final drive ratios.
both the '89-'94 v6 trucks and the tacoma v6 5 speed trucks have the same transmission gear ratios. (both are R150F).
the '89-'94 5 speed v6 trucks had a diff ratio of 4.56.
the tacomas come with a diff ratio of 3.9.
why?
because the tacoma had the bigger engine?
so (hypothetically) if i swapped in a 3.4 into a 3.0 truck, would the diff ratios need to be changed to 3.9? or i could keep the 4.56 and get bigger tires to match the factory final drive ratios?
stock 1994 Toyota 4x4 XtraCab v6 SR5 pickup
Re: gear ratios and the 3.4 questions [Re: vrooooom] #386517 01/25/04 02:36 AM
DRTDEVL Offline
I have several theories on this...
1st... The lower gear ratio uses more fuel on the highway through more RPM's. The manufacurers are always looking for ways to sneak a couple more MPG into a vehicle, even if it sacrifices performance.
2nd... The newer engines have more power, and can overcome the 3.90:1 ratio. If the 3.0 was subjected to this, a 22-RE would smoke it in all aspects of performance (assuming it kept the 4.10, 4.30, 4.56 factory ratios).
Many others have theories on this, but these are mine. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5872 MB (Peak: 0.6353 MB) Data Comp: Off Server Time: 2026-06-25 03:57:47 UTC
