Page 7 of 8 1 2 3 4 5 6 7 8
Re: electric fan. Has anybody DONE it? [Re: Dave Scott] #387379 09/20/04 04:26 PM
shifter26 Offline
thanks dave .. yeah the lift is doing awesome .. i got more pics but i dont want to cram the site like before ..
I dont know how much hp and torque i gained, but the sportage doesnt struggle anymore when stepping on the gas, ofcoarse the acceleration is still governed by the torque converter's spool lock.
Re: electric fan. Has anybody DONE it? [Re: shifter26] #387380 09/20/04 05:17 PM
Nukeiridium Offline
Shifter, what lift is that and what size tires are you runnin?
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: electric fan. Has anybody DONE it? [Re: Nukeiridium] #387381 09/20/04 09:44 PM
MorganEstill Offline
If I remember right, Shifter's running 31x11.5 Mickey Thompson Baja Claws with Dave's ~4" lift.
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: electric fan. Has anybody DONE it? [Re: Nukeiridium] #387382 09/21/04 12:31 AM
logansportage Offline
Yep, Morgan is right.
Shifter, any sagging in the springs yet?
Logansportage
Re: electric fan. Has anybody DONE it? [Re: logansportage] #387383 09/21/04 12:40 AM
shifter26 Offline
no sagging on this prototype coils ...
4" upfront (limited by the struts length, but it could have been higher with longer struts)
5.2" rear (was 5.4") 28" shocks..
the sporty is a little angled down... climbing steep hills is a little hard on initial climb but very stable because the front is lower to the ground..
Re: electric fan. Has anybody DONE it? [Re: shifter26] #387384 09/22/04 01:58 AM
This is somewhat unrelated to this particular thread, but, have we attempted to find out if there is a strut that is made that is longer? I know if you ask those "know-it-alls" at some place like Autozone or one of the others, they will say no - just like they did with my rear shocks... We ought to look into finding someone that has one of the books that shows the measurements of the shocks and look for longer struts. Just a thought. Don't know where we'd find someone with that info....
Re: electric fan. Has anybody DONE it? [Re: MorganEstill] #387385 09/22/04 01:08 PM
wd8cdh Offline
Hi Morgan,
I am in process of building some longer struts. I am trying to decide how much longer. I am thinking of making the first set 3/4" or 1" longer. What do you think?
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: electric fan. Has anybody DONE it? [Re: wd8cdh] #387386 09/22/04 03:53 PM
shifter26 Offline
1" will be pushing it .. the upper ball joint is already on an uncomfortable position after the 4" lift .. unless ur going to make a bigger stirring knuckles too .. if u do make bigger steering knuckles might as well start designing some drop brackets for the controls arms and bolt on brackets for the rear shock mount ..
Re: electric fan. Has anybody DONE it? [Re: shifter26] #387387 09/22/04 05:36 PM
wd8cdh Offline
Hi Rey,
I was thinking of no more than 1" without lowering the lower A-arms and raising the upper ball joint. I think Dave's 4" lift kit relocates the strut down about 1 1/8" and there is a slight rub on th CV boot at full droop.
I think that I can make these struts up to about 4" longer than stock but the stroke will be only about 1/2" longer than stock.
Personally, I prefer as little lift as possable for the tires so I will probably end up with 3" in the front and the rear air adjustable from 2" to 6"...........
...........oh,yea, and an electric cooling fan. (obligatory on topic content <img src="/forums/images/graemlins/rolleyes.gif" alt="" />)
Ron Schroeder
Long Island NY
Re: electric fan. Has anybody DONE it? [Re: wd8cdh] #387388 09/22/04 05:43 PM
maraguez Offline
I have 3.5" lift up front and I feel I am pushing the limits. It was real hard to get the struts in there with the lift, but it looks nice.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6483 MB (Peak: 0.7525 MB) Data Comp: Off Server Time: 2026-06-20 19:03:23 UTC
