Page 3 of 3 1 2 3
Re: Drilling frame for SAS #387628 02/02/04 03:22 PM
Exactly, pinion angle.
Re: Drilling frame for SAS #387629 02/03/04 12:53 AM
carter Offline
i dont see why the hell people dont just weld the tube under the frame,,(works in the ass end from the factory),,,,hello, it would not only make bigger tires track a little better( caster angle), but would also be much easyier,,,,,but yes on the downside,it throws off the pinion angle,,,,,,,never mind me or the beer in my hand ,or the man behind the screen.....toto were not in kansas anymore..... <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/sleeping.gif" alt="" />
People do... but it opens up some other problems:
*Pinion angle...
*Caster... too much can be as bad as not enough.
*Roll-steer because the axle moves back more as the spring compresses.
*Roll axis is raised.
The first three issues could be addressed with a larger drop hanger, you'll have a taller rig and more to hit on approach. You could also cut and turn the knuckles to address the first two. Plus, you'll have the spring hanging down farther behind the tire.
I'd just go through the frame...
Mike Carter
85 & 86 4Runners
My Website
Re: Drilling frame for SAS [Re: anthony1] #387630 02/03/04 01:23 AM
Lou Bell Offline
I just got done drilling mine using the 1/4" pilot hole and then the 1/4" rod method. I had to torch out the internal webbing, but it was easy, 15 seconds. The bi-metal hole saw cuts fast, almost no forward pressure needed. I did use cutting/tapping oil. I used the gun sight method to check if they were straight, but my holes were a tiny bit off. So I oblonged them with the hole saw a bit and now they line up great. Time to tack weld! <img src="/forums/images/graemlins/smile.gif" alt="" />(tommorrow maybe)
'87 4runner 37x12.50x15 MTRs
SAS, 4.88's, rear+front e-lockers
4x4Him --- Christian 'wheelin
4x4Him National Forum
Re: Drilling frame for SAS [Re: anthony1] #387631 02/03/04 01:26 AM
larsdennert Offline
Look'n good Anthony! I'm surprised Mike isn't there watching to give tips and avoid his own pitfalls. Two heads are better than one. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Drilling frame for SAS [Re: larsdennert] #387632 02/03/04 01:36 AM
anthony1 Offline OP
HAHA... <img src="/forums/images/graemlins/notooth.gif" alt="" />
No, he wasn't there but my two sons with goggles were with me.... <img src="/forums/images/graemlins/nana.gif" alt="" />
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Drilling frame for SAS [Re: Lou Bell] #387633 02/03/04 01:38 AM
anthony1 Offline OP
Cool! you can install the springs to make sure everything line up before you tac weld it....the 4" AP springs fit great under the IFS...:D
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6159 MB (Peak: 0.7188 MB) Data Comp: Off Server Time: 2026-06-24 08:03:09 UTC
