Page 12 of 15 1 2 10 11 12 13 14 15
Re: Well... it's that time again [Re: BigSwede] #391561 04/24/04 01:41 AM
L
Locomigo Offline OP
18, and that means this time 2 weeks from TODAY, I will be on the road, MOAB bound BABY!!!
Re: Well... it's that time again [Re: Locomigo] #391562 04/24/04 05:39 AM
muskyamigo Offline
Two weeks. This is my last weekend before Moab. I lose next weekend to my friends out of town wedding. Fortunately after tomorrow morning I only have maintenance items left to do. Wheel bearings, pinion seal, reinstall the front sway bar, change the oil, rotate the air in my tires, replace a muffler bearing, I should really replace the cracked windshield. I need a new CB antenna and associated parts. The there's the camping stuff I have to go through.
oh well. Atleast my truck is mostly assembled <img src="/forums/images/graemlins/pfft.gif" alt="" />
Mike W gettin' the jitters!
ab....mo....ab....mo....ab....moa....b....moab....moab....MOAB!!!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
Re: Well... it's that time again [Re: muskyamigo] #391563 04/24/04 05:07 PM
ridgeblazr2 Offline
17....so much to do and I'm stuck here at work!
Walt
2001 BlaZeR2
2004 Rubicon
Moab tested, Rocky Mountain approved.
http://www.imagestation.com/mypictures/index.html?view=all
Re: Well... it's that time again [Re: muskyamigo] #391564 04/24/04 05:19 PM
sweater Offline
You're lucky. I lose everything until the 6th to a trip to Italy and the UK, leaving today. It's a lot less glamorous than it sounds: all business, all tech-type cleanup at our remote offices. I had to drastically speed up the axle install, and will still be welding some stuff up at the last minute when I get back.
It looks like I'm on track to do this to myself every year... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Well... it's that time again [Re: Locomigo] #391565 04/24/04 11:27 PM
AIR AMIGO Offline
It must be getting close to Moab time.
My co-workers are shaking there heads, when they hear how much I've spent on my truck lately. I keep putting off going to the grocery store, cause it's not a priority right now. Working on the truck, and planning for the journey is all that matters.
I'm a freaking Moab addict, I even have a Moab Zu Zoo spreadsheet. I have gas, food, lodging costs, all laid out. I even spent the time to calculate my driving speeds in different areas, to know when I need to leave from point to point.
My mind's in moab, but my bodys trapped in Stevenson. HA! There is only one cure..............
MOAB ZU ZOO NOW!!!!!!!!!!!!!!!AUGH!!!!!!!!!!!!!!!
You know I bet I could do some major tire clearance, if I use the extrication tools off of Rescue 71 here! Maybe I can say I was just testing the Jaws of Life, so that they would be at the utmost ready for summer use. Think work will bite??? HAHAHA!!!
Keith
"AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc.
Pacific NW Isuzu Off-Roaders
Timber Tamers #172
Re: Well... it's that time again [Re: AIR AMIGO] #391566 04/26/04 08:03 AM
BigSwede Offline
Spent a good chunk of today in the garage, installing a TJM bumper...lotta work for a few inches more clearance up front!
Oh well, everything from here on out is "optional", not a crisis if it doesn't happen. I am now officially ready-to-go-if-I-have-to... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Of course that assumes I can get my work schedule straightened out... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Serenity now!
Re: Well... it's that time again [Re: BigSwede] #391567 04/26/04 02:17 PM
L
Locomigo Offline OP
15 days...
Yep, I hear ya, replaced the BENT up trailing links yesterday... That was interesting, including the part of having to drop the fuel tank to get the bolt out on the drivers side! <img src="/forums/images/graemlins/shocked.gif" alt="" />
Re: Well... it's that time again [Re: muskyamigo] #391568 04/26/04 08:36 PM
O
OffRodEO Offline
muskyamigo rotate the air in my tires
lol id like to know how you do this??
<img src="/forums/images/graemlins/coolg.gif" alt="" />
im just messin, i had to bring that up..
see you all in a couple weeks <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: Well... it's that time again [Re: OffRodEO] #391569 04/26/04 08:48 PM
BigSwede Offline
That's easy, just drive it! They will rotate very nicely... <img src="/forums/images/graemlins/pfft.gif" alt="" />
Since he also listed replacing the muffler bearings, I think it is safe to say he was kidding (at least toward the end of that list)...
Serenity now!
Re: Well... it's that time again [Re: Locomigo] #391570 04/27/04 01:27 AM
muskyamigo Offline
Funny, my Amigo was in a similiar condition Saturday morning. I ran out of day light friday night. I had one link that had aquired a gentle arc to it (self clearancing? ) I added a little Bling to the deal <img src="/forums/images/graemlins/coolg.gif" alt="" />
To properly rotate the air in your tires, you need 4 air tight containers, a compressor and a vacuum pump. Remove the air from each tire into the containers using the Vacuum pump. Be sure to note which tire the air in each container came from. Now move the containers to the new tires in an X pattern-left front to right rear etc. Now, this is the important part, turn the containers upside down and rotate 180 degrees( end for end). Pump the air back into the tire at the appropriate tire. Increases my tire life by 1000% and gas mileage by about 50%, of course, YMMV <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" />
Anyone know of a quick fix for a blinker fluid resevoir leak? I was thinking JB weld or something similiar? <img src="/forums/images/graemlins/nana.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Mike "smart <img src="/forums/images/graemlins/butwiggle.gif" alt="" />" W
Mike Walter
'98 Amigo well used
'01 unheated shop
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6520 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-20 18:34:38 UTC
