Re: Well... it's that time again
[Re: BigSwede]
#391561
04/24/04 01:41 AM
18, and that means this time 2 weeks from TODAY, I will be on the road, MOAB bound BABY!!!
[Re: Locomigo]
#391562
04/24/04 05:39 AM
Two weeks. This is my last weekend before Moab. I lose next weekend to my friends out of town wedding. Fortunately after tomorrow morning I only have maintenance items left to do. Wheel bearings, pinion seal, reinstall the front sway bar, change the oil, rotate the air in my tires, replace a muffler bearing, I should really replace the cracked windshield. I need a new CB antenna and associated parts. The there's the camping stuff I have to go through.
oh well. Atleast my truck is mostly assembled <img src="/forums/images/graemlins/pfft.gif" alt="" />
Mike W gettin' the jitters!
ab....mo....ab....mo....ab....moa....b....moab....moab....MOAB!!!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike Walter '98 Amigo well used '94 Rodeo in need of help '99 Ram CTD for hauling feather pillows '01 unheated shop
[Re: muskyamigo]
#391563
04/24/04 05:07 PM
17....so much to do and I'm stuck here at work!
[Re: muskyamigo]
#391564
04/24/04 05:19 PM
I lose next weekend to my friends out of town wedding. You're lucky. I lose everything until the 6th to a trip to Italy and the UK, leaving today. It's a lot less glamorous than it sounds: all business, all tech-type cleanup at our remote offices. I had to drastically speed up the axle install, and will still be welding some stuff up at the last minute when I get back. It looks like I'm on track to do this to myself every year... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
[Re: Locomigo]
#391565
04/24/04 11:27 PM
It must be getting close to Moab time.
My co-workers are shaking there heads, when they hear how much I've spent on my truck lately. I keep putting off going to the grocery store, cause it's not a priority right now. Working on the truck, and planning for the journey is all that matters.
I'm a freaking Moab addict, I even have a Moab Zu Zoo spreadsheet. I have gas, food, lodging costs, all laid out. I even spent the time to calculate my driving speeds in different areas, to know when I need to leave from point to point.
My mind's in moab, but my bodys trapped in Stevenson. HA! There is only one cure.............. MOAB ZU ZOO NOW!!!!!!!!!!!!!!!AUGH!!!!!!!!!!!!!!!
You know I bet I could do some major tire clearance, if I use the extrication tools off of Rescue 71 here! Maybe I can say I was just testing the Jaws of Life, so that they would be at the utmost ready for summer use. Think work will bite??? HAHAHA!!!
Keith "AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc. Pacific NW Isuzu Off-Roaders Timber Tamers #172
[Re: AIR AMIGO]
#391566
04/26/04 08:03 AM
Spent a good chunk of today in the garage, installing a TJM bumper...lotta work for a few inches more clearance up front!
Oh well, everything from here on out is "optional", not a crisis if it doesn't happen. I am now officially ready-to-go-if-I-have-to... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Of course that assumes I can get my work schedule straightened out... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Steve Carlson - 95 Trooper LS expo rig Serenity now!
[Re: BigSwede]
#391567
04/26/04 02:17 PM
15 days...
Yep, I hear ya, replaced the BENT up trailing links yesterday... That was interesting, including the part of having to drop the fuel tank to get the bolt out on the drivers side! <img src="/forums/images/graemlins/shocked.gif" alt="" />
[Re: muskyamigo]
#391568
04/26/04 08:36 PM
muskyamigo rotate the air in my tires
lol id like to know how you do this?? <img src="/forums/images/graemlins/coolg.gif" alt="" />
im just messin, i had to bring that up..
see you all in a couple weeks <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
[Re: OffRodEO]
#391569
04/26/04 08:48 PM
lol id like to know how you do this?? <img src="/forums/images/graemlins/coolg.gif" alt="" /> That's easy, just drive it! They will rotate very nicely... <img src="/forums/images/graemlins/pfft.gif" alt="" /> Since he also listed replacing the muffler bearings, I think it is safe to say he was kidding (at least toward the end of that list)...
[Re: Locomigo]
#391570
04/27/04 01:27 AM
Locomigo wrote: Yep, I hear ya, replaced the BENT up trailing links yesterday... That was interesting, including the part of having to drop the fuel tank to get the bolt out on the drivers side! Funny, my Amigo was in a similiar condition Saturday morning. I ran out of day light friday night. I had one link that had aquired a gentle arc to it (self clearancing? ) I added a little Bling to the deal <img src="/forums/images/graemlins/coolg.gif" alt="" /> To properly rotate the air in your tires, you need 4 air tight containers, a compressor and a vacuum pump. Remove the air from each tire into the containers using the Vacuum pump. Be sure to note which tire the air in each container came from. Now move the containers to the new tires in an X pattern-left front to right rear etc. Now, this is the important part, turn the containers upside down and rotate 180 degrees( end for end). Pump the air back into the tire at the appropriate tire. Increases my tire life by 1000% and gas mileage by about 50%, of course, YMMV <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" /> Anyone know of a quick fix for a blinker fluid resevoir leak? I was thinking JB weld or something similiar? <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Mike "smart <img src="/forums/images/graemlins/butwiggle.gif" alt="" />" W
