Please someone explain cranking the torsion bars!!! #393377 02/04/04 07:04 PM
corvettelvr73 Offline OP
I have a stock '95 with the 31" tires. I want to lift it but nothing crazy i would like to keep the 31" or maybe get 32" tires. Im thinking 2" in rear the Downey HD coils and Bilstein Shocks all around. I really dont want to do anything to the front other than an inch or so. What is all about cranking the torsion bars? How do i do it and how much will it lift? Any information is greatly appreciated. Thanks <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Please someone explain cranking the torsion bars!!! [Re: corvettelvr73] #393378 02/04/04 07:13 PM
4Crawler Offline
Here's a good writeup on the subject.
Also was a good thread on this forum in the last few months, do a search for it.
Re: Please someone explain cranking the torsion bars!!! [Re: corvettelvr73] #393379 02/04/04 07:46 PM
code33 Offline
Another good one in our own tech section.
http://www.4x4wire.com/toyota/tech/torsion_bars/
Re: Please someone explain cranking the torsion bars!!! [Re: corvettelvr73] #393380 02/05/04 12:51 AM
little_joe Offline
Former Admin
22mm socket, 22mm wrench or pipe wrench, hold the upper nut and crank on the bolt per those articles. Bounce it, drive it, then adjust to even out. Then go straight to the alignment shop.
Better bet may be to wait on the IFS balljoint spacers - this will be a superior 1.5" lift solution to cranked t-bars. Search for the 120-post "IFS Balljoint Spacer Update" thread on this forum.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Please someone explain cranking the torsion bars!!! [Re: little_joe] #393381 02/05/04 01:43 AM
elripster Offline
On this note.. Joe, when you get a chance, PM me your address. I got the parts "fixed" (I had to mill off some material) and will be sending them out Friday. Baring any major issues, and I can't fathom anything beyond mod'ing a dimension, I'm going order a whole bunch of them. I should be ready to go by the end of the month.
Frank.
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6075 MB (Peak: 0.6721 MB) Data Comp: Off Server Time: 2026-06-21 20:31:56 UTC
