Page 3 of 4 1 2 3 4
Re: trailing arm reinstallation [Re: Mendel] #394609 02/12/04 07:37 PM
Mitch Offline
Hey Mendel, how'd you bend the plate? Put it on the trailing arm and whack the !@#$ out of it? They look good.
89 Mitsubishi 2dr. V6, winch, Snorkle w/FF boot, Aisin's, sway bar discos, 15x8 rockcrawlers, 33X12.5 BFG MT's, KV85's, Snorkle install
94 Toyota x-cab, totaled
99 Dodge 2500 diesel, sold
Re: trailing arm reinstallation [Re: Mitch] #394610 02/12/04 07:45 PM
DougH Offline
Mitsubishi Forum Moderator
I would have tacked it at the front of the flate, and right before the bend. Heat it with a torch cherry hot, and use a hammer to bend it. You would be tough pressed to bend that sucker without heating it first. <img src="/forums/images/graemlins/smile.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: trailing arm bolt size? [Re: DougH] #394611 02/12/04 08:43 PM
Mendel Offline OP
Did you weld those, or did you bring them to a welder. They look well done.
I took them to a welder. Also gave them the end of the broken one so they could see where they tend to break. Also gave them pictures I found here on the wire of other trailing arm weld jobs. Lastly, gave them $30 to do both. Can't beat that. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1991 Montero LS, fading red paint
Front and rear limited slip differentials
95 SR Rear Springs, torsion bar crank, 137,650 miles
33x12.5 ProComp Mud Terrains, Bushwacker Fender flares
3 litre V6 with new heads
Re: trailing arm bolt size? [Re: Mendel] #394612 02/12/04 08:50 PM
DougH Offline
Thats a fair price for both parties. You should keep that guys number.
DougH
1995 SR - RIP
1993 RS - RIP
Re: trailing arm bolt size? [Re: DougH] #394613 02/12/04 09:36 PM
FrankR,
Check with these guys for the socket. They make all the Mitsu special tools.
Might be a lot cheaper than the stealer.
http://www.otctools.com/
Re: trailing arm bolt size? #394614 02/12/04 10:12 PM
FrankR Offline
OTC no longer makes the axle nut socket. It's now made by Miller Tools and sells for $89.95. I've ordered one, but they're on back-order until April 28th. Meanwhile a kind sold has taken pity and let me borrow his. Here's a number and contact at Miller if anyone wants the tool and doesn't mind waiting:
1-800-801-5420 - ask for Mark Patterson in Technical Support. They'll accept your credit card.
Re: trailing arm bolt size? [Re: Mendel] #394615 02/12/04 11:12 PM
NathanC Offline
That's what I needed to know. Thanks very much. Called the Stealer and the concensus from the boys was 17 mm. I've got a 17 so I knew it wasn't that small.
I'm assuming they were probably refering to the shaft of the bolt instead of the head. That is how bolts are normally sized. <img src="/forums/images/graemlins/wink.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: trailing arm bolt size? [Re: FrankR] #394616 02/12/04 11:28 PM
Lloyd Swartz Offline
I hope you do realize that is unescessary and a screw driver works fine? 89.00 is alot of cash for a gee whiz tool!
Re: trailing arm bolt size? [Re: DaphneD] #394617 02/13/04 01:12 AM
Maybe I've already got a bunch of replacement bolts... who knows? I was working on my truck today and used a 14 on several bolts on the engine. I know that most of the bolts I've replaced have had bigger heads. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I don't even want to say that out loud.
Oh, and a limited number of tools required.
And, as I originally meant to say, that's some nice welding work. $30 is great!
Re: trailing arm bolt size? [Re: Lloyd Swartz] #394618 02/13/04 01:14 AM
FrankR Offline
Yeah, I've used a screwdriver or a drift pin or two many times on other vehicles, but there was some binding on the threads and I didn't want to screw up the holes. Also, as MarkG said - the tool is very useful for making certain the bearings/races are properly seated on installation of new ones - particularly if you don't have the other gee whiz whompin' tool to seat them with.
But maybe you know a way to get leverage on the upper A-arm nuts without taking out the steering column?? Between the steering column and the A/C compressor getting in the way, I don't know whether to punt or pass at the moment. The 1/2" drive short socket is too short, the deep socket is too long and using a short extension on the short socket is too long as well. Maybe I can try a 3/8" drive deep socket with a T-flex handle. Sure hate to start grinding down a socket. No wonder the Japanese lost WWII.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6380 MB (Peak: 0.7463 MB) Data Comp: Off Server Time: 2026-06-20 17:20:28 UTC
