Page 4 of 4 1 2 3 4
Re: trailing arm reinstallation [Re: DougH] #394619 02/13/04 03:11 AM
Hey Mendel, how'd you bend the plate? Put it on the trailing arm and whack the !@#$ out of it? They look good.
I would have tacked it at the front of the flate, and right before the bend. Heat it with a torch cherry hot, and use a hammer to bend it. You would be tough pressed to bend that sucker without heating it first. <img src="/forums/images/graemlins/smile.gif" alt="" />
You guys crack me up. A simple manual hydraulic press was all that was needed for mine <img src="/forums/images/graemlins/lol.gif" alt="" />...
Re: trailing arm reinstallation - plate bending [Re: DougH] #394620 02/13/04 03:13 AM
Re: trailing arm reinstallation - plate bending [Re: off-roader] #394621 02/13/04 03:52 AM
NathanC Offline
The heck with using a press. DougH's method is the way to go <img src="/forums/images/graemlins/kewl.gif" alt="" />. Weld an end down, heat the plate and start shaping it, pausing to weld as you progress. <img src="/forums/images/graemlins/wink.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: trailing arm reinstallation - plate bending [Re: NathanC] #394622 02/13/04 04:22 AM
bretwalda Offline
I put my trailing arms back on a completely different way. With both of them off, one end of the lateral rod disconnected and the back of the frame on stands, I put a rolling floor jack under the diff pumpkin. Put in and bolted lightly the front of the trailing arms. Then jacked up the axle and scooted it around until I could easily push the bolts through - no tapping, hammering needed. The lateral rod was just as easy to reconnect - just jack up the axle. <img src="/forums/images/graemlins/kewl.gif" alt="" />
concreteprinter.com
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6126 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-06-20 16:46:28 UTC
