Re: trailing arm reinstallation
[Re: Mendel]
#394609
02/12/04 07:37 PM
Hey Mendel, how'd you bend the plate? Put it on the trailing arm and whack the !@#$ out of it? They look good.
89 Mitsubishi 2dr. V6, winch, Snorkle w/FF boot, Aisin's, sway bar discos, 15x8 rockcrawlers, 33X12.5 BFG MT's, KV85's, Snorkle install94 Toyota x-cab, totaled 99 Dodge 2500 diesel, sold
[Re: Mitch]
#394610
02/12/04 07:45 PM
Mitsubishi Forum Moderator
Hey Mendel, how'd you bend the plate? Put it on the trailing arm and whack the !@#$ out of it? They look good. I would have tacked it at the front of the flate, and right before the bend. Heat it with a torch cherry hot, and use a hammer to bend it. You would be tough pressed to bend that sucker without heating it first. <img src="/forums/images/graemlins/smile.gif" alt="" />
DougH 1997 SR - Current Lawn Ornament 1995 SR - RIP 1993 RS - RIP
Re: trailing arm bolt size?
[Re: DougH]
#394611
02/12/04 08:43 PM
Did you weld those, or did you bring them to a welder. They look well done. I took them to a welder. Also gave them the end of the broken one so they could see where they tend to break. Also gave them pictures I found here on the wire of other trailing arm weld jobs. Lastly, gave them $30 to do both. Can't beat that. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1991 Montero LS, fading red paint Front and rear limited slip differentials 95 SR Rear Springs, torsion bar crank, 137,650 miles 33x12.5 ProComp Mud Terrains, Bushwacker Fender flares 3 litre V6 with new heads
[Re: Mendel]
#394612
02/12/04 08:50 PM
Thats a fair price for both parties. You should keep that guys number.
[Re: DougH]
#394613
02/12/04 09:36 PM
FrankR, Check with these guys for the socket. They make all the Mitsu special tools. Might be a lot cheaper than the stealer. http://www.otctools.com/
#394614
02/12/04 10:12 PM
OTC no longer makes the axle nut socket. It's now made by Miller Tools and sells for $89.95. I've ordered one, but they're on back-order until April 28th. Meanwhile a kind sold has taken pity and let me borrow his. Here's a number and contact at Miller if anyone wants the tool and doesn't mind waiting:
1-800-801-5420 - ask for Mark Patterson in Technical Support. They'll accept your credit card.
[Re: Mendel]
#394615
02/12/04 11:12 PM
That's what I needed to know. Thanks very much. Called the Stealer and the concensus from the boys was 17 mm. I've got a 17 so I knew it wasn't that small. I'm assuming they were probably refering to the shaft of the bolt instead of the head. That is how bolts are normally sized. <img src="/forums/images/graemlins/wink.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
[Re: FrankR]
#394616
02/12/04 11:28 PM
1-800-801-5420 - ask for Mark Patterson in Technical Support. They'll accept your credit card. I hope you do realize that is unescessary and a screw driver works fine? 89.00 is alot of cash for a gee whiz tool!
[Re: DaphneD]
#394617
02/13/04 01:12 AM
Maybe I've already got a bunch of replacement bolts... who knows? I was working on my truck today and used a 14 on several bolts on the engine. I know that most of the bolts I've replaced have had bigger heads. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I don't even want to say that out loud. Oh, and a limited number of tools required.
And, as I originally meant to say, that's some nice welding work. $30 is great!
[Re: Lloyd Swartz]
#394618
02/13/04 01:14 AM
Yeah, I've used a screwdriver or a drift pin or two many times on other vehicles, but there was some binding on the threads and I didn't want to screw up the holes. Also, as MarkG said - the tool is very useful for making certain the bearings/races are properly seated on installation of new ones - particularly if you don't have the other gee whiz whompin' tool to seat them with.
But maybe you know a way to get leverage on the upper A-arm nuts without taking out the steering column?? Between the steering column and the A/C compressor getting in the way, I don't know whether to punt or pass at the moment. The 1/2" drive short socket is too short, the deep socket is too long and using a short extension on the short socket is too long as well. Maybe I can try a 3/8" drive deep socket with a T-flex handle. Sure hate to start grinding down a socket. No wonder the Japanese lost WWII.
