Re: my slow SAS progress......zzzzz
[Re: anthony1]
#394752
02/12/04 12:06 AM
Maybe I can turn it in to a buggy when I roll it.....
I'm sure your wife would love that!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: carter]
#394753
02/12/04 12:31 AM
I'm sure your wife would love that!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> After you roll it, use the body of your Honda Civic on your 4Runner! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
2000 - Tundra, V8 2WD Access Cab
[Re: Leo]
#394754
02/12/04 12:33 AM
I feel the love now...... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> It's friends like these that make posting rewarding.... <img src="/forums/images/graemlins/nana.gif" alt="" />
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
[Re: anthony1]
#394755
02/12/04 02:47 AM
Cut the diff mount off, but leave the torsion bar brackets.
[Re: TNToy]
#394756
02/12/04 07:29 AM
had to work late today...didn't have time or daylight to do anything....Hopefully I can leave work early tomorrow... <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: anthony1]
#394757
02/14/04 07:21 AM
Worked late again on Thursday. I got today off though so this is the result. http://home.earthlink.net/~audiorat1/images/SAS%20progress/leftside2-13-04.jpghttp://home.earthlink.net/~audiorat1/images/SAS%20progress/rightside2-13-04.jpgI'm gonna have someone box the engine mount or or put a square tube in the space there. I stil have to spot weld the sleeves for the shackle. It's easier if you mount the tie rod after you mount axle to the springs. I had to remove the springs again just to slide the springs between the hysteer tie rod and the axle. Anyone have Marlin's Hysteer? It seems that the nut for the FJ tie rod end that link the pitman arm to the steering arm is on top instead of the bottom?
[Re: anthony1]
#394758
02/16/04 10:31 AM
ok...I got the truck sitting on the ground with tires. It's too dark to take pics now. I don't have shock hoops welded in yet. Now I got the sag but problem again... <img src="/forums/images/graemlins/smile.gif" alt="" /> I plan to put new longer springs, AllPro links and pan hard rod lift in soon.
It goes down the road pretty straight except my steering wheel is turn a little side ways. I'll have to adjust that. Since my welding sucks, I plan to have the shock hoops weld it the right way.
[Re: anthony1]
#394759
02/16/04 01:44 PM
How much is the rear saggin now? Also do you think it's too high with the 2" body-lift or is it ok? I was thinking of doing the Chevy 63" rear springs when I do mine. I think it would be cheaper than running the all pro links and the extra $$ for springs.
[Re: SHAD]
#394760
02/16/04 08:22 PM
Yeah, it might be a little high but I can run longer shocks. http://home.earthlink.net/~audiorat1/images/SAS%20progress/almostdone2-15-04.jpgButt sag and all... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> The back end will be raised this weekend.
[Re: anthony1]
#394761
02/16/04 09:20 PM
The axle look pretty far forward wow.
