BRAKE DISC REMOVAL ON 95' 4WD???????????
#394994
02/07/04 08:48 AM
How do you take the darn thing off??? Im completly confused.
Re: BRAKE DISC REMOVAL ON 95' 4WD???????????
[Re: corvettelvr73]
#394995
02/07/04 03:31 PM
Former Admin
We have a complete series of front-end maintenance articles which will walk you through this. There are also some brake maintenance articles in our Toyota Section. In the maintenance articles, if you have ADD just ignore the stuff about manual hubs - you'll just have to pull off your ADD flange, which is equivalent to pulling off a manual hub body. Removing discs = great time to clean and repack bearings, new seals, etc. All of this is detailed in the articles above.
[Re: corvettelvr73]
#394996
02/07/04 03:32 PM
The disc is bolted to the hub from the inside. You have to remove the the locking hub to get to the big nut that holds the assembly together. It would be the perfect time to rebuild the hubs and "R&R" bearings gaskets the intire assembley here are some pics more info here look here
#394997
02/07/04 07:32 PM
all you need to do is read a Factory Service Manual or a Haynes repair guide for your truck...if you have one.....that was the first thing i ever bought for my truck......documentation!!!!!!
[Re: corvettelvr73]
#394998
02/08/04 02:42 AM
A nice beefy pry bar will be a very handy tool. And some PB blaster or similar lubricant.
[Re: Adam F]
#394999
02/08/04 05:04 PM
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
that too adam...i forgot about the pry bar
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6040 MB (Peak: 0.6741 MB) Data Comp: Off Server Time: 2026-06-10 04:03:21 UTCValid HTML 5 and Valid CSS
