body lift on 95 4runner
#39685
08/02/02 09:51 PM
First off, thanx to those who replied to my queries about exhaust systems and such - this is a great group of people.
Anyway, as I am looking around and going thru the archives....
I was wondering if anyone has done a 1 or 2 inch lift on their '95 3.0 4Runner 4X4 auto - and what suprises I might expect to run into.
Decided to go this route before I kick on some headers and exhaust work.
Thanks in advance
aaron s
'95 4 Runner SR5 3.0L 4x4 , A/T, D.O.A. bored T-body, K&N Filtercharger.....
Re: body lift on 95 4runner
#39686
08/02/02 10:00 PM
I did a write up of my 1" bodylift install on my mods page. Install was pretty straightforward. If you are getting Roger Brown's bodylift kit, you will have to redrill the OEM bodymounts to fit the bolts and redrill 2 holes on the front bumper. Other than that you won't have to touch anything. I left my steering and auto tranny linkage untouched and never had any problems with it. It took me 4 hours to do it, read the instructions thouroughly before you do it. Hope that helps.
2000 - Tundra, V8 2WD Access Cab
#39687
08/02/02 10:04 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Leo: <strong>I did a write up of my 1" bodylift install on my mods page. Install was pretty straightforward. If you are getting Roger Brown's bodylift kit, you will have to redrill the OEM bodymounts to fit the bolts and redrill 2 holes on the front bumper. Other than that you won't have to touch anything. I left my steering and auto tranny linkage untouched and never had any problems with it. It took me 4 hours to do it, read the instructions thouroughly before you do it. Hope that helps.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I now offer standard size mounting hardware (in addition to the larger heavy duty) so the re-drilling of the OEM body mounts is not required. I have a link to Leo's installtion writeup here.
#39688
08/03/02 04:30 AM
Also did Roger's 1" BL last weekend but had to loosen the steering clamp since the steering tilt had a little bit of binding. Just like what Roger said, he now sells an exact fit hardware bolts without redrilling the white pucks. You need to reuse all the factory washers. The front bumper hole (outer one) had to be angle grind a bit (about 1/2 the size of a dime) inorder for it to have a better fit since it looked a bit cantilevered. Also didnt touch my auto tranny but checked anything that might bind such as radiator hoses, gas filer hoses, power steering.
Chard 94 Runner V6 4X4 (gathering parts for 5spd swap and 3.4L engine swap)
#39689
08/03/02 03:36 PM
After seeing Leo's write-up, I too used one of Roger's kits on my 95. I did not touch a thing other than the body mounts and ended up breaking the bumper mount, so be careful with that. I also did not have the heavy duty hardware, so the extra drilling was avoided.
Good luck, Adrian
#39690
08/03/02 03:46 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Big_Flygt: <strong>I did not touch a thing other than the body mounts and ended up breaking the bumper mount, so be careful with that. </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">How did the bumper mount break?
#39691
08/04/02 05:30 AM
My own stupidity. I thought I had hit them hard enough with the PB Blaster, went to wrench on it and it let go. It just sped up the ARB bumper time line.
The kit was great, but the installer's quality was a little suspect.
#39692
08/03/02 07:11 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Big_Flygt: <strong>My own stupidity. I thought I had hit them hard enough with the PB Blaster, went to wrench on it and it let go. It just sped up the ARB bumper time line.
The kit was great, but the installer's quality was a little suspect.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Thanks for the clarification. Yes, soaking down parts for a week or so ahead of the installation can help with rust. Probably the hardest part of the install is the disassembly of the current parts.
#39693
08/04/02 08:03 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Big_Flygt: <strong>After seeing Leo's write-up, I too used one of Roger's kits on my 95. I did not touch a thing other than the body mounts and ended up breaking the bumper mount, so be careful with that. I also did not have the heavy duty hardware, so the extra drilling was avoided.
Good luck, Adrian</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">So Leo's write-up been good for your biz eh Roger?... <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" />
I went with 2" bl. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
#39694
08/04/02 04:31 PM
I just wanted to say that I have installed 2 body lifts on other peoples trucks. One was a Performance Accessories 2" kit, and the other was Roger's 1" kit. I personally felt that Rogers stuff was top notch. Much nicer than the PA kit. I am still considering a 1" for myself, and if I do get one, it will be Rogers kit for sure.
Josh 01 Chevy 2500HD: 6.0L gas 4x4 crew cab in search of the next trail rig
