VIEWING *ALL* ARCHIVE ENTRIES #397198 02/10/04 07:43 PM
randii Offline OP
The nature of these archived files is that many of them are older than a few weeks, so if you want to view the information, you'll need to tweak your Trail Talk Forums personal preference settings.
Look in My Home under Display Preferences. In the Default aged threads to be displayed drop-down menu, select View All...
This will allow you to view ALL of the threads by date in ALL of the forums... if you want to toggle back to a limited view after you're done in the Archives, use the same process to navigate to the Default aged threads to be displayed drop-down menu and select a shorter time period.
Hope that helps,
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: VIEWING *ALL* ARCHIVE ENTRIES [Re: randii] #397199 01/15/05 12:18 AM
randii Offline OP
You can also do this a different way...
At the bottom of each thread index page that is a drop-down list date ranges. Select from all dates and click the adjacent change button.
Note that this command makes the change in only the selected forum, as opposed to changing the default settings, which affects all forums. of available thread, i.e., the first page of a forum, you have the option to change what date range of threads you wish to view.
Randii
Randy Burleson
Mongrel Isuzu Amigo
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5860 MB (Peak: 0.6344 MB) Data Comp: Off Server Time: 2026-07-09 13:30:57 UTC
