Re: Prelminary Leak Down test results
[Re: DaJeeper]
#397507
02/12/04 03:00 AM
Offical Complete results of the Leak down test is as follows:
#1 14.4% #2 24.5% #3 17.7% #4 11.1% #5 10.0% #6 13.3%
[Re: DaJeeper]
#397508
02/12/04 08:05 AM
with those results and your stable compression.... put the jeep in service and ignor it. sounds like number 2 has valve problems.... but 24.... on an older engine..... its fine. if the smoke is bothering you see whats wrong with the head/valves.
#397509
02/12/04 08:16 AM
Well Sunder, If I wasn't getting the fouled plug on #2 I wouldn't give it a second thought. I'm certainly not looking for any extra work for sure.
I'll tell you one thing, with a fresh plug in #2 the jeep runs like heck. Very spicy motor. If I could get rid of this issue with #2 I'd be very happy.
[Re: DaJeeper]
#397510
02/12/04 09:45 AM
Sunder, another question. Is it because the compression is good that you think it's the head/valves rather than rings on the leak down test?
Also, given the compressiong and leak down test results, do you think the engine can handle the 4.0L head?
Thanks,
[Re: DaJeeper]
#397511
02/12/04 11:00 AM
Just a quick note. I have used BG44 before. It does a great job cleaning carbon and junk. If ya pour a bit on a piston head fulll of gunk, it will be clean in 5 mins. Ran it in my 79 blazer 350 and you could eat off the inside after. Ran great after use.
Where are you getting the 44 from? I havent seen it in years. Good luck with your engine man... my fingers are crossed for ya.
#397512
02/12/04 05:22 PM
[Re: DaJeeper]
#397513
02/12/04 07:06 PM
compression tests usually give you ring status adn leak down test show moe problems with valves. did you do the stethecope in the intake crank and exhaust like i suggetsted?? it will tell you ware the air is leaking out from. with good solid numbers across the board on a compression test i'd say your bottom end could take a 4.0 head.
#397514
02/12/04 07:12 PM
Sorry, haven't be able to find a Stethoscope, are they pretty cheap? Where do you pick one up?
[Re: DaJeeper]
#397515
02/12/04 07:15 PM
autozone and carquest had a cheep stethescope with a vibration probe attached to it for like 15 bucks?? i think. jsut pull the little probe off and listen.
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.012s) Memory: 0.6233 MB (Peak: 0.7094 MB) Data Comp: Off Server Time: 2026-11-17 11:23:04 UTCValid HTML 5 and Valid CSS
