Drivetrain: Unlocking the secrets of autohubs
#398301
02/12/04 08:12 AM
According to the owner's manual, it's Ok to shift between 4h and 2h on the fly, once the hubs are engaged. But they give no warning about driving in 2h with the hubs locked. Does this cause any extra wear on the front transmission? Does it affect handling or increase friction/gas consumption? Basically, are there reasonalbe limits to how fast or how far you should go with the hubs locked?
Re: Unlocking the secrets of autohubs
[Re: rumrunner]
#398302
02/12/04 03:42 PM
Driving in 2WD with the hubs locked will not affect your transmission because the transfer case is not engaged. If the transfer case is engaged with locked hubs, then you would be in 4WD.
Driving in 2WD with the hubs locked would affect fuel consumption (minimally), and maybe (although imperceptibly) affect handling to a small small degree. Essentaill, with locked hubs in 2WD, all that's happening is that your front axles, differential, and driveshaft are turning, but not "driving", i.e., you're front drivetrain is not producing any force to move the vehicle.
[Re: DaphneD]
#398303
02/13/04 07:38 AM
That's pretty much what I suspected, but by 'transmission' I meant to refer to the whole front end of the drive train. Is it bad for the front axle? I'm looking at the factory manual and I can't tell spit about how it works from the exploded views, except that I don't think I want to disassemble it (four pages of specialty tools needed <img src="/forums/images/graemlins/shocked.gif" alt="" />). Do the diff and drive shaft do the power transfer while the inner shaft gives structural support?
Is it possible to explain to a novice why 4WD on dry pavement is so bad? I understand enough about tracking to see how a locked front axle would make it extra rough, but with an open diff, why is there a problem?
1992 Mighty Max 4x4 3.0 5-speed Herculined bed
[Re: rumrunner]
#398304
02/13/04 03:45 PM
Well, driving with locked hubs in 2WD will only turn the front drivetrain, it won't be driven. So, yes it will wear on your front drivetrain, but much less than if you were in in 4WD. Do the diff and drive shaft do the power transfer while the inner shaft gives structural support? I'm not quite sure what you mean by inner shaft? In 4WD, power is transfered from transmission to the front driveshaft via the transfer case. The front driveshaft will turn the differential which then turns the front driveshafts and wheels. Is it possible to explain to a novice why 4WD on dry pavement is so bad? 4WD on dry pavement isn't necessarily bad, it's just not good. <img src="/forums/images/graemlins/smile.gif" alt="" /> Think of it like this: Your driveshafts, front and rear, are essentially like two axles when in 4WD, except with no differential in between them - it's just a straight drive. Since there is no differential in the middle of these two, there is an extra strain put on them as the vehicle goes through turns. You will feel this as a "skipping" or "rubbing" when cornering at lower speeds. It makes turning more difficult for you and the truck. When off-road, there are things like gravel, dirt, and water that allow the drivetrain to "slip" at the wheels and releive the strain on the it.
Re: Unlocking the secrets of autohubs (Archive please, IDWTWTCMTO)
[Re: DaphneD]
#398305
02/13/04 10:38 PM
It helps if you look at the tracks of all 4 wheels in mud or snow as the truck is turned. All 4 wheels travel a different distance, and the previous post says, there are diffs between the wheels on each end, but no center diff to allow different speeds between fore and aft, so you get tire scrub and strain on all the driveline components - the truck feels like it's tightening up as you turn harder, especially on hard pavement. A fair analogy is a tracked vehicle (tank/bulldozer) which has a constant track speed at all points, while distance travelled varies, so in any turn some portion of the track is skidding instead of tracking the surface.
Short take on how 4wd works:
Tranny output shaft splined to t/case input shaft, which spins a synchomeshed gear set for the low range reduction, shifted by a sliding shaft mounted fork on the synchor ring, which selects gear range (connected to 4WD shifter lever), and an additional likewise shifted dog clutch engages/disengages the chain sprocket that drives the fwd t/case output shaft. These two controls give you the ability to shift from high range to low range, and v.v., and from 2wd (driven chain sprocket disengaged) to 4wd (dcs engaged and front output shaft driven), and from h range (input shaft locked to output shaft in t/case) to lo range (input shaft locked to reduction gear train reducing output shaft speed). Most monties had auto hubs stock, which lock when the c/v shaft is driven in either direction, and unlock when 4wd is disengaged and the truck driven about 10-12' in the direction opposite that which last driven when 4wd engaged (I can hear an audible click in mine when they release. My a/t must be in neutral (not Park, that puts the driveline in a bind and you can't shift it), at slow idle, ebrake disengaged(usually), foot brake disengaged (usually), to shift into 4wd. Shift into lo range is easier, but can't be moving. Have to let the front tires get about 1-2 revolutions to lock the hubs, so go easy on the throttle until they lock.
[Re: DaphneD]
#398306
02/14/04 07:06 AM
I'm not quite sure what you mean by inner shaft? That's how the factory manual breaks down the front axle: diff, drive shaft, hub, inner shaft, and knuckle. I see now what you and fasteddy are saying about with the front to rear drive trains lacking a differential between and causing tracking problems, but I'm still not clear on the whole front drive train. Does engaging the autohubs cause the front diff to be bypassed? My under standing was that 4WD meant that 4 wheels were _capable_ of driving the truck, but only 2 wheels (1 front, 1 back) actually provided force due to the differential mechanisms. Unless there is a factory option or aftermarket modification, aren't both differentials open? If the front is open and the front drive train is not engaged to the transmission, what is causing the 'less than optimal' driving condition when the hubs are locked? Does this all boil down to different rates of fuel consumption, depending on how many mechanisms are engaged and causing friction (4H= big cut in MPG while 2H locked= slight reduction)?
[Re: rumrunner]
#398307
02/14/04 03:41 PM
The "inner shaft" you see is just an extension for the right driveshaft. The extension is needed since the differential is offset to the left side of the truck. Essentially, it is still the right driveshaft, only that part is contained inside a tube. Kinda like having a straight axle for about 8" on one side. <img src="/forums/images/graemlins/wink.gif" alt="" />
Any drive to the front of the truck MUST pass through the front differential, the same as any drive going to the rear of the vehicle MUST pass through the rear differential.
4WD means that ALL FOUR WHEELS will be turning given the right traction surface. Basically, what I think you're thinking of is that, when encountering a low traction environment (snow/ice, mud) the wheel with the most friction (traction) will stay put as all the power is transferred (via the differential) to the wheel with the least traction - the one that keeps spinning in the mud. That is the case with open differentials.
Now, if you have a limited slip differential in the rear, then you'll get more traction, i.e., the wheel that was standing still will now provide a little traction to get you out of the mud. With a differential locker, this will provide equal drive to both wheels no matter what the circumstances, so both wheels will always turn no matter what.
Fuel consumption doesn't have as much to do with the drivetrain as it does with how much the engine is running over how much distance the truck is covering. Obviously, the engine has to work a bit harder when in 4WD because it's driving more components, but the real drop in fuel consumption comes usually because in 4WD you aren't covering much ground.
[Re: DaphneD]
#398308
02/15/04 11:46 PM
Ok, I think I got it now, just one last related question: Is it normal for the front end to feel slightly different in 2H with the hubs locked? Everything seems to work properly in the various gears, but I notice a slight vibration with the hubs locked. A mechanic checked over the drive train a few months back when I had a brake job and said it was fine at the time.
[Re: rumrunner]
#398309
02/16/04 11:54 PM
Mine feels a little stiffer in that state. When the hubs are locked in 2H, the wheels are spinning the front cv axles, diff, front driveshaft, and transfer case chain and sprockets, and you can feel all that stuff turning. It causes unnecessary wear on all those components and lower mpg due to the extra friction.
