Just spent a whole lotta $$$
#398849
02/13/04 01:52 AM
Im rebuilding my front-end soon, I just ordered a bunch of parts from Allpro and Marlin. I just want to know if I got everything I will need.
Profields Cro-Mo inner axles knuckle rebuild kit 2 new wheel bearings kits 2 inner axle seals(as extras in case I mess one up putting it in) 2land cruiser front brake rotors Knuckle Pull Scale 54mm Hub Socket
I also got a couple knuckle studs, Stud Nuts, Stud Split Washers, and Stud Cone Washers just in case I loss/break any of the ones I have.
Please let me know if im forgeting anything thanks....John <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Just spent a whole lotta $$$
[Re: johnny_boy02]
#398850
02/13/04 02:23 AM
Geez...no point in getting all them parts unless you are stocked up on the #1 most overlooked item to have on hand when playing the wrenches. Other than that...aint got a clue man...sorry. ~Darin <img src="/forums/images/graemlins/baby.gif" alt="" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
[Re: Esquire812]
#398851
02/13/04 02:30 AM
Other than that...aint got a clue man...sorry. LoL, its cool, Your the engine expert. I'll need your help soon enough. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: johnny_boy02]
#398852
02/13/04 02:46 AM
Please let me know if im forgeting anything thanks....John <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> A couple of pounds of grease and I find these real handy: MAGNETIC PARTS TRAYS ò Holds small parts ò Carry with you ò Plastic protectors prevent scratches ò SX7000M-6" Round Tray ò SX7010M-9-1/2" x 5-1/2" Rectangular Tray ò SX7040M- 11-3/4" x 11-3/4" x 1-1/4" ![[Linked Image]](http://www.matcotools.com/ProductImages/SX7040M_group.jpg)
"Serenity through Sobriety"
[Re: OOP'S]
#398853
02/13/04 04:48 AM
couple of pounds of grease Thanks OOP'S, I was hoping you would chime in. What kind of grease should I use? Best place to get it?
[Re: johnny_boy02]
#398855
02/13/04 06:17 AM
couple of pounds of grease Thanks OOP'S, I was hoping you would chime in. What kind of grease should I use? Best place to get it? I use a Extreme Pressure, Moly-Graph, GP Grease made by Sta-Lube seems to work. I do not have Birfields I have an eliminator kit hhat was built by RedLine, D-44 Warn alloy axles with Spicer 670X u-joints but I used the same grease when I did have Birfields!!!! Don't forget to put some grease on the lip of the axle seal before you put the axles in!!!!
[Re: johnny_boy02]
#398856
02/13/04 06:44 PM
once you go to IFS calipers your wheels may hit them. Wheel spacers may be needed. I am only running 1/4" on mine with minimal grinding on the caliper.
[Re: Paul Elbisser]
#398857
02/15/04 01:57 AM
after doing this whole thing about 6 months ago i can tell you best advice, go generously on the moly grease. Really pack that crap in there. Oh and some other things of note would be a case of that dollar store orange oven cleaner so you can clean up the outside of the knuckle etc. Bolts go back on much better when they are clean!!!
