new header!! o2 sensor port??
#401215
02/17/04 10:56 AM
85 22re new header dosent have a port for a o2 sensor. but it runs great with out the sensor removed. do i need it? what can i expect if i leave it off?
Re: new header!! o2 sensor port??
[Re: BJWEST]
#401216
02/17/04 12:26 PM
with out the 02 sensor, I would expect the check engine light to come on. And If u have smog checks it probably wont pass.
[Re: johnny_boy02]
#401217
02/17/04 12:35 PM
i dont have to smog test. will i use more gas or loose power or any thing that matters on the trail
[Re: BJWEST]
#401218
02/17/04 02:02 PM
The o2 sensor just tells the computer if the engine is running rich/lean. So you'll probably loose some mileage, and in a worst case senario, you could run lean and start detonation.
The engine will run alright, but I wouldn't stress it too much
If we knew what we were doing, it wouldn't be research
[Re: BJWEST]
#401219
02/17/04 02:55 PM
You're running the wrong header... Either running an early 22r header or a non-cali late 22r. I'd definitely run an 02 sensor, w/o it you're running in open loop and VERY, VERY rich...
Brian K. Gallus I have nothing important to say.
[Re: BJWEST]
#401220
02/17/04 06:05 PM
Well, it depends. If the ECU knows the O2 is out to lunch it may revert to base mode and you'll give up some power- maybe. But I'd be worried that it will run way too rich and cause some bad cylinder/ring wear.
Personally, I'd get an O2 bung welded on it and reinstall the O2 sensor just to be safe.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6040 MB (Peak: 0.6730 MB) Data Comp: Off Server Time: 2026-06-23 22:13:01 UTCValid HTML 5 and Valid CSS
