blower fan not working on two low speeds #401416 02/17/04 08:23 PM
indy Offline OP
I've heard on here that the low speeds going out on the
blower motor is due to a resistor pack. Where the heck
is this thing? I dug all around under the dash on
the passenger side. I found the relay above the blower
fuse to the left of the glove box and another relay behind
the ECU on the passenger side wall, but no resistor pack
yet. If anyone has pics of this thing that may help me
find it. Untill then it's two coats of hair jell and high
speed for my defroster <img src="/forums/images/graemlins/lol.gif" alt="" />.
Regards,
Indy
Re: blower fan not working on two low speeds [Re: indy] #401417 02/17/04 08:33 PM
TheBandit Offline
I have the same problem. Only speed that works for me is "tornado". <img src="/forums/images/graemlins/mrt.gif" alt="" /> Any info on the fix would be appreciated!
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: blower fan not working on two low speeds [Re: indy] #401418 02/17/04 08:44 PM
fourwd1 Offline
On 1st gens and I think 2nd also, it's in the main duct from the heater core. Just look for a harness going to a connector. 2 screws hold it in. When removed it looks like 3 small coils of wire. If I remember correctly it's om the drivers side on a 1st gen.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: blower fan not working on two low speeds [Re: fourwd1] #401419 02/17/04 08:58 PM
4Crawler Offline
Re: blower fan not working on two low speeds [Re: 4Crawler] #401420 02/17/04 09:33 PM
Yeah what he said... <img src="/forums/images/graemlins/coolg.gif" alt="" /> Here is a picture from my EPC
Re: blower fan not working on two low speeds #401421 02/17/04 11:01 PM
indy Offline OP
Yeah, that's what I'm looking for!
I knew I'd seen it meantioned here
before somewhere, just couldn't quite
put my mouse on it though. Thanks
a bunch guys! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Regards,
Indy
Re: blower fan not working on two low speeds [Re: indy] #401422 02/18/04 03:37 AM
check the heater relay, it may be not conducting...
Re: blower fan not working on two low speeds [Re: indy] #401423 02/18/04 03:38 AM
solarcrew Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> My low speed didn't work when I got my truck.I was able to find a spring the same size as the low speed coil.I soldered it in place and bingo!It worked! <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: blower fan not working on two low speeds [Re: indy] #401424 02/18/04 07:04 AM
Zakstelly Offline
It sounds like I have a similar problem. When I got my truck it had high and low, the two speeds in between where low as well. I lost the high on a ski trip. Really could have used the defrost. Anyway I thought it might be the switch in the dash. Is this a bad place to start? Should I look at the resistor pack first?
Thanks
Zak
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
1992 X Cab 3.0L stock, blown head gasket <img src="/forums/images/graemlins/frown.gif" alt="" />
2002 Subuaru Outback
Davis CA
Re: blower fan not working on two low speeds [Re: Zakstelly] #401425 02/23/04 06:15 PM
indy Offline OP
Replaced my resistor pack this weekend.
$13 at Toyota dealership. I now can have
all four speeds once again. I believe if
you don't have high speed, looking at
either the switch or motor would be a good
place to start as high speed doesn't use
the resistor pack at all; it's straight
current to the motor. Good Luck.
Regards,
Indy
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6363 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-06-21 06:27:32 UTC
