Page 2 of 3 1 2 3
Re: Strange Idiot Lights [Re: Jim_Paget] #403204 02/22/04 11:07 PM
A
AZPetrak Offline OP
Yep this is what looks is like is happening here. Just rechecked the voltage. At battery with engine off, 12.4V, at idle 13.6V, at about 2.2K RPM, voltage drops back down.
2007 4x4 Tacoma Dbl Cab with TDR and rear locker - stock for now
2001 Wrangler Sport - sold
1998 Rodeo S 4x4 - traded in
Re: Strange Idiot Lights [Re: AZPetrak] #403205 02/22/04 11:34 PM
Canucklehead Offline
Sounds like a bad diode in the VR.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Strange Idiot Lights [Re: Canucklehead] #403206 02/23/04 02:27 AM
A
AZPetrak Offline OP
Could be a bad VR, that is what I first thought, is it part of the alt?
With 100k mile on it I will probably replace the intire thing.
Re: Strange Idiot Lights [Re: AZPetrak] #403207 03/01/04 03:29 PM
mceachrw Offline
i have this same exact problem. if you got it fixed, what was the solution?
Re: Strange Idiot Lights [Re: AZPetrak] #403208 03/01/04 03:49 PM
The Voltage regulator is internal to the alternator. You can replace it but you'll have to tear the alternator apart first.
Steve
Re: Replace Alt [Re: mceachrw] #403209 03/01/04 08:32 PM
A
AZPetrak Offline OP
I replaced the alt, $146 (I think) from Napa.
I do not have a manuel for my Rodeo so I did it "blind", let me tell you that 3.2l engine + auto trans + 4x4 = PITA alternator change.
I guess it really wasn't that bad, but it is in a tight space.
Re: Replace Alt [Re: AZPetrak] #403210 03/01/04 10:56 PM
mceachrw Offline
i'll be picking up an alternator tonight and doing it blind as well. hopefully the 5-speed 2wd is easier.
thanks
Re: Replace Alt [Re: mceachrw] #403211 03/01/04 11:16 PM
A
AZPetrak Offline OP
OK, good luck, if you get stuck, post here I will try to check this thread and can/will have you call me. It is a little tricky because there is an elongated bracket that goes under the alt, I assume it acts as a splash guard also.
I took this bracket off to get it out, but the order that I put things back together was different.
Re: Replace Alt [Re: AZPetrak] #403212 03/02/04 02:57 AM
Just remember that sometimes you can acess the alternator through the wheel well with the tire off.
Re: Replace Alt #403213 03/02/04 04:00 AM
mceachrw Offline
if anyone else has this same problem with, do NOT let it go too long. mine started 5 miles into my 35 mile commute. on the last mile, the brake and battery lights were on continuous at any rpm. when i went to leave work, the problem was still there. a volt meter read 12.6 v not running and 12.2 running from idle to 2500 rpm. luckily, we have a maintenance shop at work so i can change the alternator there tomorrow.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.015s) Memory: 0.6368 MB (Peak: 0.7270 MB) Data Comp: Off Server Time: 2026-11-18 03:28:22 UTC
