Page 2 of 3 1 2 3
Re: no high idle on cold start [Re: adam] #404577 02/23/04 05:27 AM
harliv Offline OP
Hm. Does the IAC set the high idle on cold start? I havent tried tapping on it yet. I will check that out tomorrow. Is there any easy way to tes the idle up valve?
The hose I was trying to verify goes the intake manifold and also has a t in it which goes to the ADD.
Re: no high idle on cold start [Re: harliv] #404578 02/23/04 06:15 AM
adam Offline
Defnitely maybe...how's that for an answer on the IAC.
Now, I'm looking at the FSM, and in the troubleshooting matrix it lists that A/C circuit as being a potential cause of high or low idle.
To test it looks like another continuity test - should be between the terminals but not between either one and ground.
Air also shouldn't flow between the ports unless battery voltage is applied across the terminals. This seems like the simplest test.
Personally, I went and had a beer while a professional checked it.
~Adam
Re: no high idle on cold start [Re: adam] #404579 02/23/04 06:51 AM
harliv Offline OP
Hmm. I will take a look tomorrow. The idle issue for me is just a starting problem. If I turn the key the engine will die when I let go because the idle is to low. If I tough the gas right away its fine. Seems like my truck likes these weird issues <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: no high idle on cold start [Re: harliv] #404580 02/23/04 08:12 AM
adam Offline
when was the last time you had a new gascap?
~Adam
Re: no high idle on cold start [Re: adam] #404581 02/23/04 07:20 PM
harliv Offline OP
Gas cap is fine. It was replaced recently and I still hear the pressure escape when I open it. Going to check out the IAC and the idle up valves shortly.
Re: no high idle on cold start [Re: harliv] #404582 02/23/04 08:20 PM
surlynkid Offline
my vote is the IAC. you have two vacuum lines on it. are they cracked, loose, etc? that seems most likely.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: no high idle on cold start [Re: surlynkid] #404583 02/24/04 06:59 PM
harliv Offline OP
We have a winner. It was my IAC. Soaked it with some o2 and emissions friendly carb cleaner this morning and now everything is operating as it should. I sprayed it a few times to be sure. Saved 200 bux <img src="/forums/images/graemlins/coolg.gif" alt="" />
Re: no high idle on cold start [Re: harliv] #404584 02/24/04 07:46 PM
adam Offline
Cool. I found the same thing with mine, and a liberal soaking with Deep Creep and a little tapping also did the job. My a/c circuit was definitely also fried though.
~Adam
Re: no high idle on cold start [Re: adam] #404585 02/24/04 07:59 PM
harliv Offline OP
I think my a/c idle-up valve has been dead for ~2 years. I will check that out later today. i didnt have a chance to let things warm up and check it out this morning. Hope that valve isnt too pricey smile
Re: no high idle on cold start [Re: harliv] #404586 02/24/04 08:02 PM
adam Offline
About thirty bucks afair.
~Adam
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6417 MB (Peak: 0.7453 MB) Data Comp: Off Server Time: 2026-06-17 08:00:40 UTC
