Ground wire kits? #405357 02/23/04 02:05 PM
CDUFF7 Offline OP
Is there any real benefit to these?
Re: Ground wire kits? [Re: CDUFF7] #405358 02/23/04 02:13 PM
SHAD Offline
Not really just maybe stronger starting and better spark.
I made my own kit I used 8 gauge and 4 gauge wire. Some people have used 0 and 2 gauge wire on thier vehicle.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Ground wire kits? [Re: SHAD] #405359 02/23/04 02:20 PM
CDUFF7 Offline OP
I see so many claims about horsepower gains and fuel econmy. Seems kind of hard to believe.
Re: Ground wire kits? [Re: CDUFF7] #405360 02/23/04 02:53 PM
SHAD Offline
I guess some people like myself try to mimick the grounding web effect which supposedly makes a stronger spark which is supposed to boost hp..
86 Toyota 4 runner
My cardomain page
Re: Ground wire kits? [Re: CDUFF7] #405361 02/23/04 02:53 PM
I ran a 2 gauge cable to my frame instead or running 15' of it to my rear winch. I also ran a 8 gauge wire to the fuel injection. I seems like truck runs a little better now. Not necessarily any more power.
Re: Ground wire kits? #405362 02/23/04 03:05 PM
CDUFF7 Offline OP
If it helps me run a little smoother, I may have to install some wire, I will just buy the stuff seperately - not going to buy the kit.
Re: Ground wire kits? [Re: CDUFF7] #405363 02/23/04 03:52 PM
Buster Offline
Just curious, got a link to these kits? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Ground wire kits? [Re: CDUFF7] #405364 02/23/04 04:42 PM
dknight Offline
I've never heard of a ground wire kit.
I wouldn't suggest using the frame for a winch ground. Better to run a ground wire direct to the winch.
Toyota grounding wires are marginal but adequate. Just cleaning up existing ground connections will probably gain you as much as installing new grounds. If you want to replace the wires anyway then go ahead and use bigger ones.
Re: Ground wire kits? [Re: dknight] #405365 02/23/04 05:16 PM
SHAD Offline
Here's one: http://www.z-xtreme.com/350z_Instructions.htm
You can do it yourself for alot less.
86 Toyota 4 runner
My cardomain page
Re: Ground wire kits? [Re: SHAD] #405366 02/24/04 03:51 AM
CDUFF7 Offline OP
Thank you for all the helpful information.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6325 MB (Peak: 0.7390 MB) Data Comp: Off Server Time: 2026-11-16 08:53:21 UTC
