Solid Axle Hub Problem
#406394
02/25/04 12:58 AM
Is it possible for the splined axle shaft to be out of center with the hub studs? I ask because I just screwed up the 2nd hub body that I was trying to put on there. I tried helping it on with a hammer and broke the C-clip collar on the splined piece inside the body. Seperately, both slip all the way on but together it wont go on w/o some friendly whacking which ends up breaking it. On a second note, anyone built up the end of the groove so that it'll hold a C-clip again? Not the best picture ever but gives the general situation Im in.
Re: Solid Axle Hub Problem
[Re: fpkelly]
#406395
02/25/04 01:53 AM
Have you check the steering arm nuts as well as the bottom ones? there's also the bolts that held the spindle in place. seems like something is loose that causes the birfield not to be align with the hub.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
[Re: anthony1]
#406396
02/25/04 02:10 AM
Steering arms are tight, tire spins freely and doesn't wobble. Truck has been driven 650+ miles as is so far. Does that eliminate any of those?
[Re: fpkelly]
#406397
02/25/04 06:08 AM
If you added a bunch of shims on the upper kingpin/trunion bearing cap, but didn't add any under the lower cap... then the knuckle, spindle, and hub would no longer be in alignment with the center of the axlehousing.
You should use roughly equal thicknesses of shims on the upper and lower caps to get the correct pinion preload, not just add all of them on the upper cap.
[Re: TNToy]
#406398
02/26/04 02:29 AM
So have you found the problem? tellus..... <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: anthony1]
#406399
02/26/04 02:38 AM
Nope, need to get another hub first and try to get more insight into it before I start ripping it apart.
