I need the part #'s for the speedo gear
#406467
02/25/04 02:56 AM
Yes I did a search but I need the part number and how many teeth are on the speedo trans gear.I found a shop that will test my speedo error for free. I saw that post not long ago. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: I need the part #'s for the speedo gear
[Re: 90amigo]
#406468
02/25/04 03:05 AM
Here are a few part numbers passed on to me by a good friend.
8944733080 16 Teeth 8970120851 17 Teeth 8944733040 18 Teeth 8944733031 19 Teeth 8944733021 20 Teeth
The best thing you can do is pull your old one and make calculations from there.
Michael
[Re: Jim_Paget]
#406469
02/25/04 02:06 PM
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: 90amigo]
#406470
02/25/04 08:29 PM
Not to hi-jack the post but are these gears good for manual and autos? What years are we talking here? I've got an 88 5-Speed that needs some correction. And I'll have a 98 auto as soon as a change tires.
[Re: Bigpoppax2]
#406471
02/25/04 10:10 PM
Also, are these the same part numbers for the Troopers?
#406472
02/25/04 10:58 PM
THOSE PT NO,S FOR THE SPEEDO GEARS ARE FOR THE 88-91 TROOPER 5SPD 89-91 V6 AUTO, AS THE TRANSFER CASE IS THE SAME DRIVE SETUP, ALL RODEOS WITH THE 5SPD 4WD AND THE AUTO 4WD SAME SETUP AS THE TROOPER , NOT THE 2WD, 92-97 TROOPERS AND RODEOS ALL WITH 4WD EXCEPT THE TROOPERS WITH TOD, GEARS ARE DIFFERENT ,HOPE THIS HELPS SOME OF YOU OUT JERRY
[Re: JLEMOND]
#406473
02/26/04 12:45 AM
still unclear. would these part numbers work for a 99 Trooper (automatic).
#406474
02/26/04 10:51 PM
YES THEY WILL WORK , TRANS FER CASE IS SAME DESIGN
[Re: Jim_Paget]
#406475
02/27/04 03:47 AM
My gear said 6x18.Next week I will take it to the shop.
[quote] 8944733080 16 Teeth 8970120851 17 Teeth 8944733040 18 Teeth 8944733031 19 Teeth 8944733021 20 Teeth The best thing you can do is pull your old one and make calculations from there. Michael/quote]
[Re: 90amigo]
#406476
02/27/04 03:41 PM
Are those Isuzu part no's or aftermarket??
George <img src="/forums/images/graemlins/nana.gif" alt="" /> 92 Rodeo XS 4x4 HomePage
