I need advice on which way to go on this.
I pulled the head to take a look inside. Please offer any diagnositc direction on determining where the oil is coming from. I have a fresh 4.0L head I can put on here but don't want to do it if the block is screwed up. Should I give the head to a machine shop to see if he can find anything?
I'm going to pull the valves on #2 and see what those look like but I wanted to post these to see what you guys think..
Here are the things I noticed.
The head bolts, some (a couple) had rust to a degree which made me question the quality of the ability to retain a torque. Others (about 60% were ok with a thin film of some kind of oil. The others were heavily satuated with
this funky oil. Man, this stuff stinks like the funk of 40,000 years. I don't know if this is normal or not or where this oil comes from.
I looked at the valves on #2 and they feel pretty snug there. It felt ok, both exhaust and intake.
I look at the cylinders and they "feel" good to the touch. Smooth. On the edge at the area between the cylinders (on the top rim of the cylinder wall at the area where two cylinders are closest) there is some crusty, looks
like carbon.
The gasket looks good as far as I can tell. There is a "wet" area around #2 bleeding out to the driver's side of the engine.
Anything else I can look for on this?
http://members.bigvalley.net/wuji/jeep/engine/head1.jpghttp://members.bigvalley.net/wuji/jeep/engine/cylinder2.jpghttp://members.bigvalley.net/wuji/jeep/engine/cylinder3.jpghttp://members.bigvalley.net/wuji/jeep/engine/cylinder4.jpg
