22re terrible squeeling #407074 02/26/04 02:22 AM
E
evanknight Offline OP
Hey guys
Ive had this 1992 22re pickup for about six months now. When i bought it, the engine sounded great, but over the last little while, its started squeeling whenever its running. Usually only audible when idling, but it gets pretty loud sometimes.
Friend of mine said it might be belts squeeling, and a search of the forums here half suported and half contradicted that. Any ideas?
as a side note, no maint. records, so is there any scheduled maint reccomended for 100k miles? im just hitting 98k
thanks!
1992 22re Toyota 4x4 pickup big speakers, bigger tires. rear ended <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 22re terrible squeeling [Re: evanknight] #407075 02/26/04 02:41 AM
a bearing in a pully will do it and belts will too, maybe a water pump bearing if bad enough. did u spray silly con spray on it? try that..if it goes away its a belt
john
Re: 22re terrible squeeling [Re: evanknight] #407076 02/26/04 04:11 AM
Stan_Marshall Offline
take the power steering belt off and start the engine...see if the noise is still there.
if the noise is gone, it is probably either the belt or the bearing in the idler pulley ($9 and 20 minutes to fix) or possibly the bearing in the pump itself. turn both pulleys by hand and see if they spin easily.
if the noise is not gone, take off the fan belt and start the engine. again, see if the noise is gone. if it is, you found the problem.
stan
1994 4x4 22RE W56 truck
Re: 22re terrible squeeling [Re: evanknight] #407077 02/26/04 02:57 PM
My money is on the P/S idler bearing. If you have A/C it has an idler too.
Re: 22re terrible squeeling #407078 02/27/04 12:44 AM
E
thanks alot guys! Unfortunately, belts and bearings are staying right where they are till the snow stops falling here smile
The truck itself, on the other hand, is going out for a romp in the cold!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5980 MB (Peak: 0.6606 MB) Data Comp: Off Server Time: 2026-06-17 14:35:50 UTC
