Re: winch installation [Re: Gellekanao] #407713 02/28/04 03:43 AM
bretwalda Offline
Alex Kogan on this board did a spectactular setup for his Gen2.
I havent seen any update on this but it sounds like using the stock bumper was possible with this configuration
concreteprinter.com
Re: winch installation [Re: Lloyd Swartz] #407714 02/28/04 04:06 AM
DavidG Offline
Rob, you raise very good points and I absolutely agree with the safety issues. I can honestly say that right now I don't need one, but after getting previous rigs stuck, I now I would like a winch in the future. My greatest concern is altering the airbag deployment.
I've seen ARB bumpers build specifically to handle proper deployment, and that's what I'm after. Unfortunately, it appears an airbag-compatible bumper is not available. I would rather get stuck without a winch than fool around with the impact sensors and endanger my family. Besides, this thing is only driven offroad maybe 5% of the time and I'm much more likely running into another vehicle driving to work. Still, I wish I could find the right application.
Do you guys think a 4-5k class 3 hitch would hold up to the potential 8-9k lb pull of a receiver mounted winch? Oh, and Lloyd, thanks for the offer. The center portion of the factory bumper just begs for that sort of custom treatment!
Thanks guys,
David
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: winch installation #407715 02/28/04 04:45 AM
Gellekanao Offline OP
Alternatively, Warn sells a "pull pack"...basically, a winch mounted to a trailer drawbar...plug it in your receiver, hook cables up to your battery, and away you go!
That's exactly what 4-wheel parts told me when I called them. It could only pull back though....Kinda awkward not unless you install a hitch in the front of your vehicle.
stephen <img src="/forums/images/graemlins/cheers.gif" alt="" />
Exploring the outback is my game!
2005 Mitsu Gen3 Limited
OME Custom Suspension
Custom made safari roof rack
Garmin GPS
32X12.50X16 BFG Mud Terrain
1997 Mitsu Gen2 LS
Safari Roof rack
Garmin GPS
33x11.50x15 BFG MUds
Re: winch installation [Re: Gellekanao] #407716 02/28/04 04:50 AM
Thanks for all your help guys! I guess I'm stuck with the good ol' high lift jack <img src="/forums/images/graemlins/kewl.gif" alt="" />
thanks again,
Stephen
Garmin GPS
1997 Mitsu Gen2 LS
Safari Roof rack
Garmin GPS
Re: winch installation [Re: Gellekanao] #407717 02/28/04 05:44 AM
It's possible to winch in the opposite direction. But you need lots of cable, pulleys, and a little luck with fixed anchors in the right places...
What about cutting a small hole in the front bumper to accomodate a pass through for what would amount to a receiver. Have it pass through to a plate that then spreads side-to-side so that it can tie into the frame rails. That is actually what I have been pondering on.
As for the 4-5k rating on the receiver, I'll bet the rating is more a function of the Montero's ability to tow safely across the roadways. Somebody posted on a thread a little while back that a pintle hook mounted to the back plate could handle 10k...
Re: winch installation [Re: MontyMcV] #407718 02/28/04 05:51 AM
N
NumLock Offline
yes some of the vans at work have trailer hitche on the front and back with red cables going to them. so they are for a winch? that is a very cool way to mount the winch.
thanks for the info.
Paul
88 Montero, 2'lift, 31X10.5, front locker.
"Because you're mine, I walk the line."
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6182 MB (Peak: 0.7055 MB) Data Comp: Off Server Time: 2026-11-18 11:45:19 UTC
