Attn: XM radio or radio installers #408107 02/27/04 05:31 PM
Dbryan22 Offline OP
My connection diagram says I need to attach one wire to "a terminal always supplied with power regardless of ignition switch position." Can anyone help me out here with a suggestion of where I should attach this wire? Thank you.
2001 SR5 4Runner 4x4
Re: Attn: XM radio or radio installers [Re: Dbryan22] #408108 02/27/04 06:42 PM
Chris V Offline
What are you installing????
1996 T100 SR5, 4" Procomp Stage2,
33x12.5x15 tires
http://members.cardomain.com/chris_t100
Re: Attn: XM radio or radio installers [Re: Dbryan22] #408109 02/27/04 07:38 PM
Battery? Fuse box? if you run it to the fuse box get a test light or meter and find a hot wire when the key isnt on, but try not to use the headlights or something important so you dont overload (although it shouldnt be a problem) but you never know. Then enjoy the XM, it beats the hell outa local radio <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Attn: XM radio or radio installers #408110 02/27/04 07:40 PM
you could just run it to your head units constant 12 right?
Re: Attn: XM radio or radio installers #408111 02/27/04 07:53 PM
Not on my Taco its not. Not even the cig. lighter will work without the key turned,unlike all my prev. trucks.
Re: Attn: XM radio or radio installers #408112 02/27/04 08:21 PM
when you install an aftermarket stereo it has a constant 12 volt to it. as with a stock unit, when you remove the battery you lose your presets etc and sometimes have to enter a code. thats the 12 volts i'm talking about. <img src="/forums/images/graemlins/coolg.gif" alt="" />
Re: Attn: XM radio or radio installers #408113 02/27/04 10:17 PM
Dbryan22 Offline OP
I was thinking of the constant power supply to the aftermarket radio. The reason is so you don't lose presets when you turn off the vehicle. Thanks everyone.
Re: Attn: XM radio or radio installers [Re: Dbryan22] #408114 02/28/04 01:15 AM
one of the 12 volts to the radio is switched so get the right one
Re: Attn: XM radio or radio installers #408115 02/29/04 02:37 PM
DRTDEVL Offline
It should be a yellow wire to the radio...
BTW: Tis is what actually powers the radio... The "memory" wire. The "power" wire is nothing but a switch, like for a relay.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6167 MB (Peak: 0.6977 MB) Data Comp: Off Server Time: 2026-06-12 22:28:24 UTC
