Re: 54MM Socket [Re: fpkelly] #409925 03/02/04 08:09 AM
fpkelly Offline OP
Got a quick question, when converting from ADD to Warn manual hubs, does one need the 54mm nuts and washers from my (donor) truck, do they have them already on their ADD truck? Only asking because I want to ship them ASAP but cant get them off the one side.
Re: 54MM Socket [Re: fpkelly] #409926 03/02/04 03:51 PM
Kaptain Offline
You can use channel locks to take them off, but remember those nuts need to be properly torqued so you have the correct bearing preload when you put it all back together. As far as needing the 54mm nuts, i see no reason why the ADD truck will not have them..
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: 54MM Socket [Re: fpkelly] #409927 03/02/04 04:47 PM
mt_goat Offline
Yes, you will still need the 54mm nuts when going from live (ADD)hubs to manual hubs. Those nuts hold your wheel bearings in place. We have a place called Steve's Wholesale here in OKC that sells those 54mm spindle nut sockets for about $12. <img src="/forums/images/graemlins/smile.gif" alt="" />
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: 54MM Socket [Re: mt_goat] #409928 03/02/04 06:34 PM
if it is ADD, you dont need to remove the spindle nuts, it already has the proper ones since you are just replacing a drive flange with the lockout. on vehicles with auto hubs, you need to buy the nuts and the lock ring.
Re: 54MM Socket #409929 03/02/04 07:48 PM
fpkelly Offline OP
Excellent, I'll just leave these on and ship the hubs out and he'll just leave his in place.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6077 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-21 01:17:37 UTC
