Need advice on ECM repair
#410792
03/03/04 05:34 AM
My Monty just up and died yesterday while I was cruising down the freeway. Mechanic says that the ECM is damaged and will need to be replaced. Was planning to send it to avpro ecm to have the work done.
Now for the question. Do we assume that the ECM failed simply because it is old or should we spend a lot of time and money searching for something that may have caused the failure? I read about the ISC thing and the possibility that this could damage the ECM.
I am inclined to assume it is the ECM that has failed on its own and have it replaced. I welcome any and all opinions for or against. Anything else other than the ISC should be checked?
Thanks
1991 Montero LS, fading red paint Front and rear limited slip differentials 95 SR Rear Springs, torsion bar crank, 137,650 miles 33x12.5 ProComp Mud Terrains, Bushwacker Fender flares 3 litre V6 with new heads
Re: Need advice on ECM repair
[Re: Mendel]
#410793
03/03/04 06:07 AM
I seem to remember a post once that said bad spark plug wires could cause an extra load on the ecu. If you still have the original wires it might be worthwhile to get a new set. In your case it could also have just been the age and miles on the unit. Several folks have had to repair/replace the ecu recently--the 3 electrolytic capacitors get old and start leaking acid on the circuit board, next thing you know, it fries or dies. Mine fried, so I bought a used one from a junkyard, I replaced the capacitors as a precaution. So far, so good. Keep us informed of what happens, and good luck.
90 Montero, 2dr, AT, V6, LSD, AC, KYB shocks, bouncy seat, 182K miles, JDM engine, 87 Starion seats, tow hitch http://www.geocities.com/idahojack03/Index
Re:advice on ECM repair
[Re: Mendel]
#410794
03/03/04 06:18 AM
It might be the crank angle (photo optical thing) sensor. I don't Know the test for this but getting the module for around $125 from CarQuest or other reputable dealer who carriers STANDARD BRAND electrical part,,,and they have to look it up in the big book ,,,not on the screen.
Very IMPORTANT and MOVE fast...There is a 90-91 federal emissions ( no egr) rebuilt ECU on EBAY ,,,,and the guy give really good diagnostic suggestions. READ what he says before spending the big bucks. There is a rebuilder place in Houston you send yours with two day turnaround,,,NCM I think. Dave , The Junk Yard Dog of Sacatomato
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
