80 amp fuse
#411984
03/05/04 12:46 AM
I have a friend that put his battery in back-ass-ward <img src="/forums/images/graemlins/shocked.gif" alt="" /> No, it wasn't me! Anyway, he was inquiring on how to remove the 80 amp fuse to replace it. Anyone know the procedure. My shop manual isn't handy at this time. Thanks danny
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
Re: 80 amp fuse
[Re: toyrunner]
#411985
03/05/04 01:17 AM
Its in a holder, release the clips with a skinny flat screwdriver and push it up through the housing. Or is that down through it? shooot....anyways its bolted to the wires with 7mm or 8mm bolts. Easiest access by unbolting the whole block from the inner fender, unhooking the other connector clips and going at it from the bottom. ~Darin <img src="/forums/images/graemlins/baby.gif" alt="" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
Re: 80 amp fuse
[Re: Esquire812]
#411986
03/05/04 01:33 AM
You have to pull the mounts for the fuse box then loosen some wire up push the fuse up through then use a cross it to remove the screws that hold the wires to the fuse.
Re: 80 amp fuse
[Re: toyrunner]
#411987
03/05/04 03:00 AM
It has a clip lock, just push it with a screwdriver, push the fuse and holder down. One bolt on each side. Should take about 5 minutes.
Re: 80 amp fuse
[Re: toyrunner]
#411988
03/05/04 03:03 AM
Also as a precaution, check the B+ termianl on the alternator to make sure it's not burnt. Hopefully the fuse did its job <img src="/forums/images/graemlins/shocked.gif" alt="" />
Re: 80 amp fuse
[Re: kewlynx]
#411989
03/05/04 05:23 AM
Thanks for all the replies. Gonna tackle this tomorrow after doing a brake job on my sisters 82 pickup <img src="/forums/images/graemlins/sleeping.gif" alt="" /> Danny
PHP: 7.4.33 Page Time: 1.983s Queries: 15 (0.003s) Memory: 0.6085 MB (Peak: 0.6782 MB) Data Comp: Off Server Time: 2026-05-30 04:47:52 UTCValid HTML 5 and Valid CSS
