Detroit Electrac? #412314 03/05/04 07:58 AM
Does anyone out there know the story regarding applications or fitment charts for the Detroit Electrac? I seem to have run into a bit of a brick wall as far as what diffs this locker is going to work on. Especially regarding Isuzu reare-ends specifically. Any info would be greatly appreciated! Thanx-
Toddzu/HI <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Detroit Electrac? #412315 03/05/04 02:07 PM
FIEND Offline
I know they came out for the D44 but I myself am not sure how different our rear end in comparison.If anything this thread got a bump to the top...LOL
<img src="/forums/images/graemlins/shiner.gif" alt="" />
I got your Jeep thing and now it burns when I pee!
http://www.mwior.com/ The "Official" web page for an "Official" MWIOR!!
Re: Detroit Electrac? #412316 03/05/04 02:12 PM
RobG Offline
If the Electrac is available for your standard D44, the those with 1st gen Isuzu D44's should be able to get the one thats available for the 3.54 and down gearset and use any set of stock isuzu gears. If you're upgrading gears and going with an aftermarket gearset, then you will need the 4.10 and up carrier. those with the 2nd gen isuzu d44 may have a bit more of a problem as there have been some possible oddities talked about with those lately, i won't hazard a guess there.
disclaimer, no first had knowledge here, just speaking off the way i understand things.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: Detroit Electrac? #412317 03/05/04 04:57 PM
kobyhud Offline
They have them for any Dana 44, and for dana 60s as well. Pretty much there are two dana 44s, 3.73 and down carrier and 3.73 and up carriers. Isuzu dana 44 rear ends are funky in that they have a 4.10 or 4.30 gear in a 3.73 and down carrier. So if you ever plan on doing the gears as well. You better do the gears and the locker at the same time.
As for the electrac, you may wanna be careful, call up tractech before you buy and make sure that they have sorted out their problems first.
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Detroit Electrac? [Re: kobyhud] #412318 03/06/04 01:08 AM
Rodeo Guy Offline
Someone got the electrac in his rodeo...i'm not positive but I think it might be MattGold, I don't think hes active anymore though. So yes its possible, you just gotta do what RobG said. Rob is always right <img src="/forums/images/graemlins/smile.gif" alt="" />
I think I would like the electrac for the front because it is a good lsd when unlocked, so if you are going through a difficult section that needs precise steering, but still an open front won't quite get yah there- that sounds like the way to go to me. Of course, it is not available for isuzu front ends.
Mike
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Detroit Electrac? [Re: kobyhud] #412319 03/06/04 02:36 AM
Thanx Fellas! <img src="/forums/images/graemlins/kewl.gif" alt="" />I have a 96 with the 4.10-geared D44 rear-end, and am extremely interested in the Electrac as an option to the mega$$$-ARB. Kobyhud-Which problems are you referring to? Is Tracktech suffering some kind of problem with the product?
Re: Detroit Electrac? #412320 03/06/04 04:38 PM
Rodayo Offline
mega$$$-ARB.
Have you seen how much the Electrac costs? About the same as an ARB from the couple of places I've seen offering it.
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Detroit Electrac? #412321 03/06/04 06:18 PM
TXCO RIG Offline
Go to indy4x.com and go to the FAQ section and they list the various axles and applications.
99 Trooper 3" Indy lift,Rancho 9000's,RIP
91 Trooper 2.4l, Indy 3in,32x11.5,5 BFG's on black Rock Crawlers,Confer rack ,Pro Comp lights,Warn hubs,XM radio
97 Zj
Re: Detroit Electrac? [Re: Rodayo] #412322 03/06/04 08:11 PM
sweater Offline
mega$$$-ARB.
Amen here.
ARB's cost less, but you have to factor in a compressor. Since I'm getting a compressor for something like $40 from a kind soul at work, two ARB's work out to be less than two Electracs.
The debate here, IMHO, is if one is better than the other. I like ARB's proven reliability, but the air line thing somewhat scares me. I'm just planning on running really really good lines in very protected, not-kinked places. But the fact that you electrically fail a Detroit and then just "bolt in" your locking status is kinda cool...
Re: Detroit Electrac? [Re: sweater] #412323 03/07/04 02:34 AM
Rodeo Guy Offline
Yep, when you factor in the cost of compressor, if you are getting just one, it is slightly cheaper. And I'm very happy with my lockright in the rear, if I get to the point that I think it is too weak or I actually break it, I will probably get a detriot or upgrade to dana60 or something.
One extra plus, is the cool little button with the lightning on it. And when you press it, it is totally silent while locking in. Arb makes a little whirrr, tips people off. Hahahaha, that is such a dumb reason. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Mike
Mike
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.008s) Memory: 0.6371 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-07-14 12:20:49 UTC
