Monty's and Mountain Bikes
#412451
03/05/04 04:48 PM
Hello all, Monty newbie, and 1st time poster here. I'm shopping for a vehicle to carry mountain bikes & my family of 4 to camping and trails (mostly mountain biking trips). It will also be used as a daily driver.
I've spent hours searching the archives here, and I'm convinced the Montero is the great & reliable vehicle I need. I want something with good interior volume/storage space, and am so glad I didn't buy that Trooper I was looking at last month. <img src="/forums/images/graemlins/lol.gif" alt="" />
Within my price range, I've narrowed my search down to a '97 due mainly to the simpler SOHC design. I have found an SR, and an LS in my price range. The LS has 35k less miles than the SR, but still is nicely equipped with leather, moonroof, etc. I don't see myself taking full advantage of the locking differential on the SR, although Moab is just as holy for mountain biking as it is for wheelin'.
I will use it on fireroads, and even simple 4x4 trails while camping and on vacation. I am very involved locally with MTB trail advocacy and trail building. (By the way, I'm impressed with the trail advocacy presence on 4x4Wire). I will use the vehicle to get tools and equipment to off-road trailwork sites.
I'm leaning towards the LS because it's clean, it's local, and it's got low miles. Isn't the LS still a capable, above average 4WD vehicle? Again, no rock crawling.
1) Other than the locking diff. and 2.5" factory lift, what are the differences in the SR/LS?
2) Does anyone carry their bikes inside the truck? What kind of set-up is required? Can I carry 2-bikes in back, and still use the 2nd row of seats?
Thanks in advance, Dave in KC
Re: Monty's and Mountain Bikes
[Re: davemtb]
#412452
03/05/04 05:13 PM
Hello!
I am able to put (2) 19" mountain bikes inside by removing the front wheels and using an old Yakima crossbar with (2) mounts for the front fork and they fit nicely. I mainly use the roof mounted rack but at times when I need to run into town and will be away from my truck I feel safer by putting the bikes inside. Also, there are tie downs inside for extra security/stability. The bar can slide a little but if you use the tie downs its secure. I have the LS version (2000) and wish I had the locking diffs, but as of yet I have not needed them. I am not getting out like I want! You should be fine with the LS for what you will be using it for. Good luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
2000 Montero, ARB bumper, TJM snorkle, OME suspension, Maggiolina Extreme RTT, BFG KM2's 33/10.5/15. ARB fr/rear lockers, 3.15 transfer case.
[Re: RogerH]
#412453
03/05/04 05:35 PM
you should be able to fit 2 bikes behind the second row seats if you take both wheels off.
Maybe not necessary for your situation but they help sell the car...Get one with third row seats. Very well designed third row seats I should add.
I still say hold out for the locker. Take it from a guy that wasnt into wheeling and modifying his 92LS when he got it but who was eventually bit by the bug. Figure that's a $1k feature minimum to add on if you ever wished you had it. Also with the SR you get the extended fender flares, and 31" tires.
concreteprinter.com
[Re: davemtb]
#412454
03/05/04 06:00 PM
The few times I've had my 95 LS (MT) out, it was not on gnarly stuff, but pretty challenging for some. It did fine without the locker (or LSD). The only time I did suffer was in climbing a decent sized steep rock in a creek. Couldn't do it and had to stack a few. On my first trip with it a guy with a trail-only Cherokee led us down a trail that he said we could mae it, but then seemed a little surprised with how easily I did it. <img src="/forums/images/graemlins/coolg.gif" alt="" />
Nonetheless, I do see me with ARBs in the future. Also, I used to have a 95 SR and had it in some pretty good snow that took low and lock to bust out of. Don't know if more rocking and a push would have done it without the locker or not.
If you'er looking at and SR, then it is 3.5L isn't it? (I thought the SR went out with the 3.5.) In which case, even though the engine has a rep for being tough to work on, the plus is the 214HP. Boy do I miss mine. (No MTs for the 3.5 though and I'm a sap for shifting. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />)
BTW, welcome to the board. When you buy whatever it is, be sure to add the details to your profile.
[Re: MontyMcV]
#412455
03/05/04 07:12 PM
Hi, Monteros and mountain bikes <img src="/forums/images/graemlins/kewl.gif" alt="" /> here's a pic of my monty it's a Gen I, with a yakima racks for 4 bikes, this way you leave all the space inside for passangers and equipment, or put the bikes inside it has a lot of roof clearance ![[Linked Image]](http://www.jeeperos.com/photopost/data/500/578flares-med.jpg)
Mitsubishi Montero 1990 LWB, Rear Air locker, SAS D44, superwinch hubs, bouncy seat, moonroof, custom brushguard, custom rack, GPS Meridian Magellan, dual Red Optima Red, Bilstein 7100 shocks, Hellas, 35x12.50 R15 Muds, 10,000 winch
[Re: MontyMcV]
#412456
03/05/04 07:17 PM
From what I've read, I believe the '97 LS & SR both used the SOHC 3.5 which is supposed to be easier to work on than the DOHC.
Thanks for the info on the bikes guys. My new job is less than 3 miles to some MTB trails, and I plan to keep my bike locked up in the back a lot for before and after work rides. Sounds like it's going to work out well.
Roger, thanks for the info on how the LS works for you. I imagine that if it works for you & your 19" bikes in Phoenix it should work for me here.
Thanks again, Dave
Dave Smith '96 SR - 31x10.5 Tires
"Facts are meaningless. You could use facts to prove anything that's even remotely true!" Homer Simpson
